    Fix HP Printer issue on macOS
HP PCs - Troubleshooting USB Connections (Windows 10, 8)
This document applies to HP and Compaq computers with Windows 10 or Windows 8.
This document describes common errors and general troubleshooting tips for Universal Serial Bus (USB) devices, such as hubs, thumb drives, printers, and cameras.
Depending on your version of Windows, some graphics and information in this document might vary slightly.
Before you begin
Some USB devices, such as printers, scanners, and copiers require that the USB device software and drivers be installed before connecting the USB device to the computer. Always follow the installation documentation from the USB device manufacturer.
While troubleshooting the USB device, you might need to disconnect the USB device from the computer.
Always follow manufacturer instructions for disconnecting USB devices from the computer. Some USB devices must be turned off and/or ejected before they are disconnected from the computer. Some other USB devices support the Windows Safely Remove Hardware feature.
Troubleshooting steps
Perform the following steps, as applicable, to troubleshoot USB devices that are not working correctly:
  1. Power: If the USB device operates on battery power, make sure the batteries are correctly seated and are functional. If the USB device operates on external power, make sure all the power connections are secure and the power cord is connected to a power source.
  2. Test the USB connection: Sometimes, simply disconnecting and reconnecting the USB device to the computer can solve the problem:
    1. Disconnect all USB devices from the computer except a USB mouse and keyboard (if in use). This includes hubs, thumb drives, printers, and cameras.
    2. With all USB devices disconnected, do one of the following:
      • If you have a desktop computer, connect the device that is not working correctly to one of the USB ports on the back of the computer (the ports attached directly to the motherboard).
      • If you have a notebook computer, connect the device that is not working correctly to a USB port on the notebook. Do not use a USB port replicator (such as a docking station or USB hub).
    What happens when the device is connected?
    • The device works correctly: The problem is most likely related to power or poor overall system performance.
      To prevent the USB device from failing in the future: Do not connect too many devices to the computer; wait 5 seconds after connecting a device before using it; use powered hubs to connect other devices; and do not attach USB devices when the system is busy (running slower than normal).
    • The device does not work: Leave the device connected and continue to the next step.
  3. Installing USB manufacturer software: Some USB devices require manufacturer software be installed before the USB device will work.
    1. If the USB device came with software, and it was not previously installed, install the software now, following the manufacturer instructions.
    2. After installing manufacturer software, reconnect the USB device that was having problems.
    The device should now work correctly. If problems persist, continue to the next step.
  4. Microsoft easy fix solutions: Microsoft provides a web-based automatic diagnostic and repair application. Go to the How to use Microsoft easy fix solutions webpage (in English) and select the troubleshooter that most closely matches your issue. Then follow the on-screen instructions. If the device still does not work, go to the next step.
  5. Windows Update: Running Windows Update checks for operating system updates required for your computer. Go to Windows Update (in English) and follow the on-screen steps to check for updates, and opt in on all recommended and optional driver updates. If the device still does not work, go to the next step.
  6. Microsoft System Restore: If the USB device was previously working, then subsequently became unusable, try Microsoft System Restore to go back to a time prior to when the device failed. Refer to Using Microsoft System Restore (Windows 10, 8) for more information. If the device still does not work, go to the next step.
  7. Device Manager: You might be able to troubleshoot the problem using the Device Manager.
    In Windows, search for and open Device Manager.
    Follow the instructions below, depending on how your device is listed in the Device Manager:
    • Unknown Device: A driver is not installed or was not set up correctly (Such as, when a USB device was removed while Windows was still setting it up as newly found hardware.). To correct this problem, uninstall and reinstall the driver for the device, as follows:
      1. Disconnect the device.
      2. Right-click Unknown Device, and select Uninstall.
        The Confirm Device Uninstall window opens.
      3. Click the box next to Delete the driver software for this device (if it is shown).
      4. Click OK.
      5. Restart the computer.
      6. Reinstall the device per the manufacturer instructions.
    • Other Device: The USB ports are working but device drivers need to be installed. To correct this problem:
      1. Disconnect the USB device, and wait 20 seconds.
      2. Install the drivers per the manufacturer instructions.
    • Device Name is shown: USB ports and basic plug-and-play are working correctly. There is a physical problem with the device or there is an issue with the device drivers. One of the following steps might resolve the problem:
      • Restart the computer and try connecting the USB device again.
      • Disconnect the USB device, uninstall the device software (if any), then reinstall the software.
      • Uninstall and reinstall the device as follows:
        1. With the device connected, right-click the name of the device in Device Manager and select Uninstall.
        2. Click the box next to Delete the driver software for this device (if it is shown).
        3. Click OK.
        4. After the name of the device is removed, disconnect the device and restart the computer.
        5. Try installing the device again per the manufacturer instructions.
      • If the device is a communication device, double-click the device name and set the COM port to a different number; from COM4 to COM3 for example.
    • Device is not listed: If the device is not listed at all, go to the next step.
  8. Uninstalling USB Root Hubs: Uninstalling USB Root Hubs forces the system to reinstall the root hubs next time the computer is started. Use the following steps to uninstall USB Root Hubs:
    1. Disconnect all USB devices connected to the computer except a USB mouse and keyboard (if in use). This includes hubs, thumb drives, printers, and cameras.
    2. In Windows, search for and open Device Manager.
      The Device Manager window opens.
    3. Double-click Universal Serial Bus Controllers to expand the list.
      Figure : Universal Serial Bus controllers list in Device Manager window
    4. Right-click the first USB Root Hub in the list, then select Uninstall.
      Figure : Uninstall selection in the Device Manager window
      Click OK to confirm.
    5. Continue uninstalling all USB Root Hubs listed.
    6. Close Device Manager and restart the computer.
    7. If the USB device that is having problems came with software and it was not previously installed, install the software now, following the manufacturer instructions.
    8. Reconnect the USB device that was having problems and test it to see if it works.
USB 2.0 device not detected by Windows (no device name in Device Manager)
If the USB device does not display in Device Manager, there might be a power requirement issue.
Disconnect the device and perform the following steps until the device is detected:
  1. Restart the computer.
  2. Connect the device and wait 5 seconds. If the device is not recognized, disconnect it and go to the next step.
  3. In Windows, search for and open Device Manager.
  4. Double-click Universal Serial Bus Controllers to expand the list.
  5. Double-click a USB Root Hub, click the Power tab, then click Power Properties (if it is shown).
    The Power tab displays only in USB 2.0. There is no Power tab in USB 3.0.
    Devices that are attached to the hub are shown, as well as the power that they require. If the total displayed power is over 500 mA, remove the devices and use a powered hub.
    Figure : USB Root Hub Power Properties window
  6. Continue looking at the power properties of each USB hub. If the total Power Required exceeds the Total power available for the hub, then remove a device on that hub to lower the Power Required number.
  7. Connect the device and wait 5 seconds. If the device is not recognized, disconnect it and go to the next step.
  8. Remove high-speed USB cables that are over 3 m (9.8 ft) in length and use high-speed cables that are shorter than 3 m.
    Only use high-speed cables shorter than 3m in length with high-speed USB devices (multifunction printers, scanners, and cameras).
  9. If the USB device is connected to a USB port on a keyboard, disconnect it, then connect it to a USB port on the computer or to a powered hub.
  10. There might be an issue with the USB port. Try connecting to a different USB port. If the USB device displays in Device Manager after connecting the cable to a different port, then uninstall and reinstall the USB device software driver.
  11. Consult the manufacturer of the device for support if the device still fails to display.
USB storage device is not shown in Safely Remove Hardware window
If you connect a USB storage device, such as a flash drive, the device might not display in the Safely Remove Hardware window when you click the Safely Remove Hardware icon in the Windows desktop notification area.
Figure : Safely Remove Hardware taskbar icon
USB storage device: The USB device might not display if it was stopped previously and not disconnected from the USB port.
To resolve this issue, disconnect the device, wait approximately 20 seconds, then reconnect the device to cause the device to display in the Safely Remove Hardware window.
If the device still does not display in the Safely Remove Hardware window, then restart the computer, and repeat this process.
Memory card in a USB card reader: If the device is a memory card in a USB card reader, restarting the computer should correct the problem.
Do not use the Safely Remove Hardware icon to remove a memory card. To remove a memory card, use Windows to eject the card by following these steps:
  1. Insert a memory card when the light on the reader is not flashing.
    An Autoplay window displays. If it does not display, open the card using Window Explorer.
  2. The memory card has a drive letter associated with it, just like a floppy drive, CD-ROM drive, or hard drive. Use the memory card as you would use any other drive on the computer. For example, double-click the memory card icon to open a new window showing the files on the CompactFlash card.
  3. When you have finished working with the files on a memory card, right-click the memory card icon and select Eject.
    Figure : Eject Removable Disk selection
  4. Wait for the light on the memory card reader to turn off or stop flashing.
  5. Remove the memory card from its slot.
Front USB ports do not work on a desktop computer.
If your desktop computer came with USB ports on the front of the computer and they do not work, a cable inside the computer might have become disconnected. First, make sure the USB ports at the rear of the computer work by connecting a USB device to the rear port. If the device is not recognized in the rear port, then use the other sections in this document to resolve the problem. Use the following steps to see if the front USB ports have become disconnected from the motherboard:
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Turn off the computer, disconnect the power cable, and position the computer so that you can easily work on it. If necessary, disconnect cables and move the computer to a table over a non-carpeted floor.
  2. Remove the side panel. If needed, you can find instructions that specifically match your computer by searching HP Customer Support (at the top of this page) using the model number of your computer and the term "opening the case".
    Figure : Removal of side panel (your computer might look different but is similar)
     Image of the side panel being removed.
  3. Look inside the computer. Wires coming from the USB PCA board at the front of the computer are routed to a set of USB pins on the motherboard. Make sure this connection is secure. If the wires are not connected or are partially connected, secure the wires to the proper USB connection on the motherboard.
    To find where the USB connector is located on the motherboard, look for 5 pairs of pins with a label that starts with USB, JUSB, FRONT_USB, or F_USB. If your motherboard has two sets of pins, FUSB1 and USB2 for example, use the lower number first. Also, you can refer to the motherboard specification that matches your specific model of computer. Find the motherboard specification from the HP Customer Support for your computer model.
    Figure : An example of front USB wires connecting to the motherboard
     Image of USB connection on motherboard
  4. After the Front USB wires are securely connected, replace the side panel.
  5. Make sure there are no devices or cables connected to the front USB ports.
  6. Connect the power cable (and the mouse and keyboard if they were previously disconnected).
  7. Turn on the computer and wait for Windows to find the new hardware.
  8. You can use the front ports after Windows has installed drivers for the USB ports.
The mouse responds slowly, if at all
If your computer does not recognize the mouse or if the mouse is very slow to respond, download and install the latest USB 3.0 driver.
Not every computer or mouse needs this update.
  1. Go to the HP Drivers & Support webpage.
  2. Use one of the available methods to identify your computer model. The software and driver results page displays when the computer model is identified.
  3. Click Driver – Chipset.
  4. Download the USB 3.0 Driver, then follow the on-screen instructions to complete the installation.
  5. After the driver has downloaded and installed, restart the computer.
USB 2.0 Device Does Not Work When Connected to a USB 3.0 Port
Some USB 2.0 devices will not work when connected to a USB 3.0 port. To fix this, uninstall the USB 3.0 driver in Device Manager using the following steps.
  1. In Windows, search for and open Device Manager.
  2. Locate the USB 3.0 Root Hubs under Universal Serial Bus Controllers.
    Figure : Locating the USB Root Hub
  3. Right-click the USB 3.0 Root Hub, and click Uninstall.
