HP PCs - Creating a Wireless Home Network (Windows 10, 8)
This document pertains to HP and Compaq computers with Windows 10 and Windows 8.
Windows allows you to connect multiple computers in a home network. This is a convenient way to share files in the home. This document provides instructions for setting up and sharing folders and files on a wireless home network.
Setting up a local network and file sharing
Use the steps in this section to set up a home network using wireless hardware.
To perform some of the steps in this document you must be logged into Windows using the main administrative account. Normally this is the first account that was created when the computer was first turned on.
Accessing shared files and directories on a local network
Do the following to access shared files and directories:
  1. Make sure network discovery and file sharing is turned On.
  2. In the Windows search box, type View network computers and devices.
  3. The Network window opens and displays computers with shared folders that are detected on local networks.
  4. Double-click the computer you want to access.
  5. If prompted, enter the username and password to access that computer.
