HP Compaq LA2405x 24-inch LED Backlit LCD Monitor Product Specifications
Product description
HP Compaq LA2405x 24-inch LED Backlit LCD Monitor delivers high screen performance in one flexible, widescreen design to boost the team productivity, backed by HP and built with the environment in mind. It is for those that demand expanded screen real-estate and solid screen performance backed by strong and on-going support from HP.
Product features
Feature
Type
Twisted Nematic (TN) LED Backlit LCD
61 cm (24 in) widescreen; diagonally measured
Active area (H x W)
32.4 x 51.84 cm (12.7 x 20.4 in)
Aspect ratio
16:10
Viewing angle (typical)
Up to 170° horizontal and 160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 cd/m² (nits)
Response time (typical)1
5 ms (On/Off)
User programmable modes
Yes, 25
Anti-glare
Yes
Default color temperature
6500 K
Tilt range
-5° to +30°
Swivel range
-170° to +170°
Height adjustable
Yes, up to 12 cm (4.72 in)
Pivot rotation
Yes, 90° to portrait
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Panel specifications
Specification
Type
Active area (H x W)
Aspect ratio
16:10
250 cd/m² (nits)
Contrast ratio (typical)1
1000:1
5 ms (On/Off)
Pixel pitch
0.027 cm
Backlight lamp life (to half brightness)
30,000 hours
Color gamut (typical)
72%
Color support2
Display up to 16 million colors
2: With the use of FRC technology.
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
OSD menu, OSD down, Source select/OSD up, Auto adjust/OK, Power (from left to right)
Languages
English, French, German, Spanish, Italian, Netherlands, Japanese, S.Chinese, T.Chinese and Brazilian Portuguese
User controls
Brightness, Contrast, Color, Image Control, OSD Control, Management, Language, Information, Factory Reset, Source Control, Exit
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 76 kHz
Vertical frequency
50 to 63 Hz
Native resolution
1920 x 1200 @ 60 Hz (full high definition), 16.7 million pixels
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1200 @ 60 Hz
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1600 x 1200 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 960 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 640 x 480 @ 60 Hz
Text mode
Not supported
Maximum pixel clock speed
200 MHz (analog input); 170 MHz (DVI and DP input)
Yes, 25
Anti-glare
Yes
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Self powered USB 2.0 hub
One upstream, two downstream ports (cable included)
Input signal
VGA, DVI-D, and display port connectors
Input impedance
75 ohms ± 10%
Video cable
One DVI-D to DVI-D, one 15-pin D-sub (VGA)
Video cable lengths
VGA 1.8 m (5.9 ft), DVI-D 1.8 m (5.9 ft)
USB cable
One USB
USB cable length
1.8 m (5.9 ft)
Power specifications
Specification
Input power
Auto-sensing, 95 to 265 V ac
Typical power consumption
29 W (with USB 25% load)
Maximum
39 W
Power saving
< 0.5 W
Power cable length
1.9 m (6.2 ft)
Frequency
45 to 63 Hz
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked with stand:
  • 55.68 x 27.84 x 38.05 to 48.75 cm (21.9 x 11.0 x 15.0 to 19.2 in)
Unpacked without stand (head only):
  • 55.68 x 6.4 x 36.26 cm (21.9 x 2.5 x 14.3 in)
Packaged:
  • 65.9 x 23.0 x 55.1 cm (25.9 x 9.1 x 21.7 in)
Head only:
  • 4.1 kg (9 lb)
Unpacked:
  • 6.8 kg (15 lb)
Packaged:
  • 10.1 kg (22.3 lb)
Tilt range
-5° to +30°
Swivel range
-170° to +170°
Height adjustable
Pivot rotation
Base
Attachable, ships attached
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C (102°F) maximum wet-bulb
Operating altitude
0 to 5,000 m (0 to 16,404 ft)
Non-operating altitude
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass
Yes
Mercury free
Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
