HP 3115m Notebook PC - Removing and Replacing the Hard Disk Drive Assembly
This document is provided to assist in removing and replacing the hard disk drive assembly for the HP 3115m Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small, smooth-tipped needle nose pliers (optional)
  • Tweezers
  • Small, Phillips-head (P1 and P00) screwdrivers
Parts required
The replacement part number will vary depending on the hard disk drive assembly that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
320GB SATA hard disk drive - 5,400 rpm, 2.5-inch, 7 mm form factor (raw drive)
645193-001
Yes
Solid state drive SATA 160GB
659933-001
Yes
500GB DRV Hard disk drive 5400 rpm SATA raw 2.5-inch
669299-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labelled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive assembly, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Hard disk drive assembly from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive assembly removal video (right-click on the link to open in a new window/tab).
Hard disk drive assembly removal
  2.   note:
    The following video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
  3. Using the black Mylar tab on the hard disk drive adapter cable, disconnect the hard disk drive adapter cable from its connector on the system board.
  4. Remove the hard disk drive adapter cable from the routing channel on the base enclosure.
  5. Remove the 5 mm P1 Phillips-head screw that secures the hard disk drive assembly to the base enclosure.
  6. Grasp the Mylar tab on the left of the hard disk drive assembly and lift the left side of the hard disk drive assembly up.
  7. Slide the hard disk drive assembly out of the hard disk drive bay and place it in a static dissipative bag.
Hard disk drive assembly replacement
  1. Remove the hard disk drive assembly from the static dissipative bag.
  2. Toe the right side of the hard disk drive assembly into the hard disk drive bay.
  3. Lower the left side of the hard disk drive assembly into position in the hard disk drive bay.
  4. Replace the 5 mm P1 Phillips-head screw that secures the hard disk drive assembly to the base enclosure.
  5. Using the black Mylar tab on the hard disk drive adapter cable, connect the hard disk drive adapter cable into its connector on the system board.
  6. Route the hard disk drive adapter cable through the routing channel on the base enclosure.
