HP Z620 Workstation - Removing and Replacing PCIe Graphics Card
This document is provided to assist in removing and replacing the PCIe graphics card for the HP Z620 Workstation.
Minimum skill level
Parts required
The replacement part number will vary depending on the PCIe graphics card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
AMD FirePro 2270 PCIe x16 512MB graphics card - Comes with a Full-Height (FH) mounting bracket
637213-001 (Modified)
Yes
ATI Firepro V3900 PCI-E (x16) 1GB graphics board
677982-001 (Modified)
Yes
AMD FirePro V4900 PCIe 2.1 x16, 1GB GDDR5 memory graphics card
654594-001 (Modified)
Yes
AMD FirePro V5900 PCIe 2GB memory graphics card
654595-001 (Modified)
Yes
AMD FirePro V7900 PCIe 2GB memory graphics card
654596-001 (Modified)
Yes
NVIDIA Quadro NVS 300 PCIe 2.0 x16 graphics card - With 512MB DDR SDRAM memory
632486-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quadro NVS 310 512MB PCIe X16
680653-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quadro 2000 1GB PCIe
671136-001 (Modified)
Yes
NVIDIA Quadro4 NVS 400 PCIe 512MB DDR SDRAM memory graphics card
645557-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quado 4000 2GB PCIe
671137-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quadro 410 512MB PCIe
680652-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quadro 5000 2.5GB PCIe
671138-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quadro 600 1GB PCIe
671135-001 (Modified)
Yes
NVIDIA Quadro 6000 PCIe graphics card - With 6.0GB GDDR5 GPU memory, maximum resolution 2560 x 1600, maximum power consumption (204 W), one Dual Link DVI-I and two Display Ports connections
616078-001 (Modified)
Yes
Printed Circuit Assembly (PCA) Quadro NVS 450 512MB PCIe
689470-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the PCIe graphics card, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select PCIe graphics card from the menu on the upper left hand side of the screen.
PCIe graphics card removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the auxiliary power cable from the card.
  3. Press the two release latches and rotate the PCI retention clamp until it is fully open.
  4. Push out and hold the locking tab on the PCIe slot and partially lift the front end of the card out of the slot.
  5. If the card has a support bracket, press the release tab on the PCI card guide and lift the back end of the card out of the slot.
  6. Lift straight up on the card to remove it from the chassis.
    If customer is not replacing the card with another card, cover the open slots on the PCI bulkhead with metal slot covers.
PCIe graphics card replacement
  1. If customer is installing a new graphics card, remove the slot covers from the appropriate slots on the PCI bulkhead.
    Some cards require two slots.
  2. Align the connectors on the card with the slot on the system board.
  3. If the card has a support bracket, align it with slot in the PCI card guide.
  4. Lower the card down over the slot on the system board.
  5. Press down on the card until it is fully seated.
  6. Rotate the PCI retention clamp down over the PCI bulkhead.
  7. Press the two PCI retention clamp tabs on the rear of the chassis until they lock into place.
  8. Connect the auxiliary power cable to the card.
  9.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
Country: Flag Vietnam
