HP Z620 Workstation - Removing and Replacing Battery
This document is provided to assist in removing and replacing the battery for the HP Z620 Workstation.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery for Real-Time Clock (RTC) - 3.0 V, 200 mAh, lithium disc cell, 20 mm diameter, 3.2 mm height (CR2032)
234556-001 (Original)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Battery from the menu on the upper left hand side of the screen.
Battery removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Push in on the battery through the notch in the battery socket to release the battery.
  3. Lift the battery out of the socket.
Battery replacement
  1. Push the battery into the socket with the positive (+) sign facing up.
  2.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
