HP Z620 Workstation - Removing and Replacing Second CPU Memory
This document is provided to assist in removing and replacing the second CPU memory for the HP Z620 Workstation.
Summary of instructions
To view a video demonstrating the procedure for removing the second CPU memory, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Second CPU memory from the menu on the upper left hand side of the screen.
Second CPU memory removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Pull out on the latch and rotate the airflow guide back until it is fully open.
  3. Push down and out on the memory socket latches to release the memory module.
  4. Pull the memory module up and out of the socket.
Second CPU memory replacement
  1. Ensure that the memory socket latches are pushed down and away from the memory socket.
  2. Match the notch on the memory module with the key in the memory socket.
  3. Push the module down firmly into the socket until the latches snap into place and the module is fully seated.
  4. Rotate the the airflow guide over the PCA board and push until its snaps into place.
  5.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
Country: Flag Vietnam
