HP Z620 Workstation - Removing and Replacing Optical Drive
This document is provided to assist in removing and replacing the optical drive for the HP Z620 Workstation.
Minimum skill level
Parts required
The replacement part number will vary depending on the optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
SATA DVD-ROM 16X SMD nonLS optical drive (Jack Black color)
660408-001 (Modified)
Yes
682550-001 (Modified)
Yes
SATA DVD+/-RW SMD Slim Slot optical drive
682551-001 (Modified)
Yes
DVD 6x/8X BD-Writer nonLS Drive (Jack Black Color)
656792-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the optical drive, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Optical drive from the menu on the upper left hand side of the screen.
Optical drive removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the data and power cables from the drive.
  3. Pull out on the release latch and slide the drive out of the drive bay.
Optical drive replacement
  1. Push the drive into the drive bay until it stops.
  2. Lift the release latch and slide the drive in about half an inch.
  3. Release the latch and continue pushing the drive until it locks into place.
  4. Connect the power and data cables to the drive.
  5.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
