HP Z420 Workstation - Removing and Replacing the PCIe Graphics Card
This document is provided to assist in removing and replacing the PCIe graphics card for the HP Z420 Workstation.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the PCIe graphics card that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP.
Part Number
Requires Return
AMD FirePro V4900 PCIe 2.1 x16, 1GB GDDR5 memory graphics card
654594-001 (Modified)
Yes
AMD FirePro V5900 PCIe 2GB memory graphics card
654595-001 (Modified)
Yes
AMD FirePro V7900 PCIe 2GB memory graphics card
654596-001 (Modified)
Yes
NVIDIA Quadro NVS 300 PCIe 2.0 x16 graphics card - With 512MB DDR SDRAM memory
632486-001 (Modified)
Yes
PCA Quadro NVS 310 512MB PC
680653-001 (Modified)
Yes
NVIDIA Quadro 2000 PCIe graphics card - With 1GB GDDR5 GPU memory, 128-bit memory bus width
616075-001 (Modified)
Yes
NVIDIA Quadro4 NVS 400 PCIe 512MB DDR SDRAM memory graphics card
645557-001 (Modified)
Yes
NVIDIA Quadro FX 4000 2GB PCIe graphics card
616076-001 (Modified)
Yes
Quadro 410 512MB PCIe card
680652-001 (Modified)
Yes
NVIDIA Quadro 5000 PCIe graphics card - With 2.5GB GDDR5 GPU memory, maximum resolution 2560 x 1600, one Dual Link DVI-I and two Display Ports
616077-001 (Modified)
Yes
PCIe NVIDIA Quadro 600 graphics adapter card - With 1GB DDR3 SDRAM memory
616074-001 (Modified)
Yes
PCA Quadro NVS 450 512MB PC
689470-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the PCIe graphics card, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select PCIe graphics card from the menu on the upper left hand side of the screen.
PCIe graphics card removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the auxiliary power cable from the card. Press the two release latches and rotate the PCI retention clamp until it is fully open.
  3. Push out and hold the locking tab on the PCIe slot and partially lift the front end of the card out of the slot.
  4. If the card has a support bracket, press the release tab on the PCI card guide and lift the back end of the card out of the slot.
  5. Lift straight up on the card to remove it from the chassis.
PCIe graphics card replacement
  1. If a new graphics card is being installed, remove the slot covers from the appropriate slots on the PCI bulkhead.
    Some cards require two slots.
  2. Align the connectors on the card with the slot on the system board.
  3. If the card has a support bracket, align it with slot in the PCI card guide.
  4. Lower the card down over the slot on the system board.
  5. Press down on the card until it is fully seated.
  6. Rotate the PCI retention clamp down over the PCI bulkhead.
  7. Press the two PCI retention clamp tabs on the rear of the chassis until they lock into place.
  8. Connect the auxiliary power cable to the card.
    The graphics card requires auxiliary power. On some cards a 6-to-8 pin power adapter cable from one of the auxiliary power cables is used to extend power to the card.
Please refer to the product-specific Maintenance and Service guide for any future technical information and/or installation guidelines for this component.
