Document ID: c03284077
Version: 1
HP Notebook PCs - Windows 7 Does Not Recognize the Optical Disc Drive
Release date : 16-Apr-2012
Last updated : 16-Apr-2012
DESCRIPTION
After using the Group Policy Editor to configure the operating system image, Microsoft Windows 7 does not recognize the optical disc drive (ODD) .
SCOPE
HP ProBook 4530s Notebook PC
HP ProBook 4730s Notebook PC
RESOLUTION
To resolve this issue, do the following:
  1. Click Start, type gpedit.msc and select Group Policy Editor from the search results list.
  2. Select Computer Configuration. DO NOT select User Configuration. Doing so may result in the issue described in this document.
  3. Select Administrative Templates.
  4. Select System.
  5. Select Removable Storage Access.
  6. On the right side, click the CD and DVD: Deny Write Access option, then select Enabled.
For more information on Group Policy management, see Group Policy management for IT pros on the official Microsoft website.
Hardware platforms affected : HP ProBook 4530s Notebook PC, HP ProBook 4730s Notebook PC
Operating systems affected : Microsoft Windows 7 Professional (32-bit) (deleted)
Support Communication Cross Reference ID : IA03284076
