Document ID: c03280705
Version: 1
Advisory: HP Z1 Workstation - Limited Functionality Under RHEL 5.7 or RHEL 5.8
Release date : 11-Apr-2012
Last updated : 17-Apr-2012
DESCRIPTION
Several features of the HP Z1 Workstation, that work properly under other Linux OSes, are inoperative under RHEL 5.7 or RHEL 5.8. These include:
  1. built-in speakers and some other audio functions (although headphones do work);
  2. wireless LAN;
  3. Bluetooth;
  4. USB 3.0;
  5. IEEE 1394a;
  6. media card reader
Configuration:
RHEL 5.7 and RHEL 5.8 operating system installed (32- or 64-bit).
Symptoms:
These features are inoperative. RHEL 5 is not expected to be certified on HP Z1, so no support from Red Hat can be expected.
SCOPE
Information in this document applies to the listed systems configured as follows:
Systems:
  • HP Z1 Workstation
Operating Systems:
  • Red Hat Enterprise Linux 5 (x86)
  • Red Hat Enterprise Linux 5 (x86_64)
RESOLUTION
No known workaround or solution supported by HP.
Hardware platforms affected : HP Z1 Workstation
Operating systems affected : Red Hat Enterprise Linux 5 (x86) (deleted) Red Hat Enterprise Linux 5 (x86-64) (deleted)
Support Communication Cross Reference ID : IA03280705
