Document ID: c03280215
Version: 1
HP Notebook PCs - Cannot Use SCCM to Push BIOS vF.25 to Client Over Network
Release date : 11-Apr-2012
Last updated : 11-Apr-2012
DESCRIPTION
When using Microsoft System Center Configuration Manager (SCCM) to push the BIOS vF.25 update to a client over a network, the server cannot push the update and the update fails.
SCOPE
HP EliteBook 8460p Notebook PC
RESOLUTION
In order to flash the BIOS over a network, do one of the following:
  • In a command line interface, type the following command and press [Enter]:
    hpqflash.exe -s -a -f68SCF.CAB -phpqssm.bin
  • Extract the SP56699.exe file to a folder with an SP56699.CVA file, then run HOQRUN.exe. HOQRUN.exe references the MAP.INI file and then flashes BIOS vF.25 to a client in silent mode.
Hardware platforms affected : HP EliteBook 8460p Notebook PC
Operating systems affected : Microsoft Windows 7 Professional (64-bit) (deleted) Microsoft Windows XP Pro
Support Communication Cross Reference ID : IA03280102
