HP LaserJet Pro MFP - Delete faxes from memory
Use this procedure only if you are concerned that someone else has access to your product and might try to reprint faxes from the memory.
In addition to clearing the reprint memory, this procedure clears any fax that is currently being sent, unsent faxes that are pending redial, faxes that are scheduled to be sent at a future time, and faxes that are not printed or forwarded.
  1. From the Home screen, touch the Setup button.
  2. Touch the Service menu.
  3. Touch the Fax Service menu.
  4. Touch the Clear Saved Faxes button.
