    Windows 11 Upgrade Guide
HP LaserJet Pro 300/400 color M351/M451 Series Printer - Replace the print cartridges
The product uses four colors and has a different print cartridge for each color: black (K), magenta (M), cyan (C), and yellow (Y).
If toner gets on any clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  1. Open the front door.
    Figure : Open the front door
  2. Pull out the print-cartridge drawer.
    Figure : Open the print-cartridge drawer
  3. Grasp the handle on the old print cartridge and then pull the cartridge straight up to remove it.
    Figure : Remove the old print cartridge
  4. Remove the new print cartridge from the packaging.
    Figure : Remove the new print cartridge from the packaging
  5. Gently rock the print cartridge from front to back to distribute the toner evenly inside the cartridge.
    Figure : Gently shake the cartridge
  6. Remove the orange, plastic shield from the bottom of the new print cartridge.
    Figure : Remove the packing material
  7. Do not touch the imaging drum on the bottom of the print cartridge. Fingerprints on the imaging drum can cause print-quality problems.
    Figure : Do not touch the imaging drum
  8. Insert the new print cartridge into the product.
    Figure : Insert the new cartridge
  9. Pull the tab on the left side of the print cartridge straight up to completely remove the sealing tape. Recycle the sealing tape.
    Figure : Remove the sealing tape
  10. Close the print-cartridge drawer.
    Figure : Close the print-cartridge drawer
  11. Close the front door.
    Figure : Close the front door
  12. Place the old print cartridge, the sealing tape, and the orange plastic shield in the box for the new print cartridge. Follow the recycling instructions that are included in the box.
