HP 1912nm 18.5-inch Internet Monitor - Setting Up the Monitor
Preparing the monitor for desktop use
To assemble the monitor for desktop use:
  1. Set the monitor screen face down on a flat, soft, protected table or desk surface with the support column overhanging the edge.
  2. Align the center column with the base and push the center column onto the base (as shown in item 1 of the figure below). Then align the monitor support column with the center column and push the monitor all the way onto the center column (as shown in item 2 of the figure below) until it snaps securely in place.
  3. Lift the monitor to an upright position and place on a flat, stable surface.
Preparing the monitor for wall-mounting
This apparatus is intended to be supported by UL or CSA Listed wall mount bracket.
To attach the monitor to a mounting fixture:
  2. If the center column and base are attached to the monitor, pinch together the two release tabs on the bottom of the base (as shown in item 1 of the figure below) and pull the base off the center column (as shown in item 2 of the figure below). Then press the button on the rear of the center column (as shown in item 3 of the figure below) and slide the center column off the monitor support column (as shown in item 4 of the figure below).
  3. Remove the two screws that attach the support column to the monitor (as shown in item 1 of the figure below), then slide the support column back and remove it from the monitor (as shown in item 2 of the figure below).
  4. To attach the monitor to a mounting fixture, insert four 10 mm screws through the holes on the mounting plate and into the mounting holes on the monitor.
    This monitor supports the VESA industry standard 100 mm mounting holes. To attach a third-party mounting solution to the monitor, four 4 mm, 0.7 pitch, and 10 mm long screws are required. Longer screws must not be used because they may damage the monitor. It is important to verify that the manufacturer’s mounting solution is compliant with the VESA standard and is rated to support the weight of the monitor display panel. For best performance, it is important to use the power and video cables provided with the monitor.
Country: Flag Vietnam
