HP 650 Notebook PC - Spare Parts
New model specific parts lists
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website for this product.
Spare parts
Item
Component
Spare Part Number
1
Display assembly
The display assembly is spared at the subcomponent level only. For more display assembly spare part information, see Display assembly subcomponents section.
2
Keyboard (includes keyboard cable)
For use in Belgium
646125-A41
For use in Bulgaria
646125-261
For use in Canada
646125-DB1
For use in the Czech Republic
646125-221
For use in Denmark, Finland, and Norway
646125-DH1
For use in France
646125-051
For use in Germany
646125-041
For use in Greece
646125-DJ1
For use in Hungary
646125-211
For use in Israel
646125-BB1
For use in Italy
646125-061
For use in Latin America
646125-161
For use in the Netherlands
646125-B31
For use in Portugal
646125-131
For use in Russia
646125-251
For use in Saudi Arabia
646125-171
For use in Slovenia
646125-BA1
For use in Spain
646125-071
For use in Switzerland
646125-BG1
For use in Turkey
646125-141
For use in the United Kingdom
646125-031
For use in the United States
646125-001
3
Top cover (includes the TouchPad board)
687703-001
4
Power button board (includes cable)
686270-001
5
TouchPad button board (includes bracket, TouchPad button board cable, and TouchPad cable)
686271-001
6
Speakers (include speaker cables)
686279-001
7
Optical drive connector cable (includes bracket)
686257-001
8
USB board (includes cable)
686269-001
9
System board (includes replacement thermal material)
Equipped with Intel HM75 Express chipset and for use with computer models equipped with an Intel Core i5 or i3 processor
687701-001
Equipped with Intel HM70 Express chipset and for use with computer models equipped with an Intel Pentium or Celeron processor
687702-001
10
Processor (includes replacement thermal material)
Intel Core i5-3210M 2.50-GHz processor (3.0-MB L3 cache, 35 W)
680645-001
Intel Core i3-3110M 2.30-GHz processor (3.0-MB L3 cache, 35 W)
682417-001
Intel Core i3-2370M 2.40-GHz processor (3.0-MB L3 cache, 35 W)
677152-001
Intel Core i3-2350M 2.20-GHz processor (3.0-MB L3 cache, 35 W)
653340-001
Intel Core i3-2308M (2.10-GHz processor 3.0-MB L3 cache, 35 W)
693542-001
Intel Pentium B970 TJ85 2.30-GHz processor (2.0-MB L3 cache, dual core, 35 W)
676785-001
Intel Pentium B960 TJ85 2.20-GHz processor (2.0-MB L3 cache, dual core, 35 W)
664662-001
Intel Celeron DC B820 1.70-GHz processor (2.0-MB L3 cache, dual core, 35 W)
690537-001
Intel Celeron DC B815 1.60-GHz processor (2.0-MB L3 cache, dual core, 35 W)
677153-001
Intel Celeron DC B730 1.80-GHz processor (2.0-MB L3 cache, dual core, 35 W)
690536-001
11
Fan/heat sink assembly (includes replacement thermal material)
686259-001
12
Power connector cable (includes bracket)
686258-001
13
Base enclosure (includes battery cover lock latch, battery cover release latch, power connector barrel, and RJ45 cover)
686253-001
Rubber feet kit (not illustrated, includes front and rear rubber feet)
686276-001
14
Battery
6-cell, 55-Wh, 2.55-Ah, Li-ion battery
593554-001
6-cell, 47-Wh, 2.20-Ah, Li-ion battery
593553-001
DVD±RW Double-Layer with SuperMulti Drive (includes optical drive bezel and optical drive bracket)
686268-001
16
RTC battery
686274-001
17
Hard drive (does not include hard drive bracket, hard drive connector cable, or screws)
750GB, 5400 rpm, 9.5 mm
634250-001
640GB, 5400 rpm, 9.5 mm
669300-001
500GB, 5400 rpm, 9.5 mm
669299-001
320GB, 5400 rpm, 9.5 mm
622643-001
Hard drive hardware kit (not illustrated, includes hard drive bracket, hard drive connector cable, and screws)
18
Memory module (PC3, 12800, 1600 MHz)
4GB memory module
652972-001
2GB memory module
641369-001
19
WLAN module
Atheros AR9565 802.11b/g/n 1×1 WiFi + BT4.0 Combo Adapter
690019-001
Atheros HB125 802.11b/g/n 1×1 WLAN module
675794-001
Atheros 9485GN 802.11b/g/n 1×1 WiFi and 3012 Bluetooth 4.0 Combo Adapter
655795-001
Broadcom 4313GN 802.11b/g/n 1×1 WiFi and 20702 Bluetooth 4.0 Combo Adapter
657325-001
Ralink RT5390F 802.11b/g/n 1×1 WLAN module
670691-001
Ralink RT5390R 802.11bg/n 1×1 WiFi Adapter
691415-001
Ralink RT3290LE 802.11b/g/n 1×1 WiFi and Bluetooth 4.0 Combo Adapter
690020-001
Cover kit, includes
686272-001
20
Hard drive compartment cover (includes one captive screw, secured by a C-clip)
21
Memory module/wireless module compartment cover (includes one captive screw, secured by a C-clip)
Item
Component
Spare Part Number
1
Display bezel
686254-001
2
Webcam/microphone module (includes double-sided adhesive)
686285-001
3
15.6-inch HD LED Anti-Glare display panel (raw panel)
687700-001
4
Display hinge cover kit (includes left and right display hinge covers)
686260-001
5
Display hinges (includes vertical support brackets)
686262-001
6
Display panel cable (includes webcam/microphone module cable)
686256-001
7
Antenna kit (includes wireless antenna left and right (main and auxiliary) cables and transceivers)
686249-001
8
Display enclosure
687698-001
9
Display rubber kit1 (includes display assembly rubber bumpers and screw covers)
686275-001
1. Not illustrated in the image above.
Mass storage devices
Item
Component
Spare Part Number
1
750GB SATA hard disk drive - 5,400 RPM, 9.5-mm, 2.5-inch form factor (raw drive)
634250-001
640GB SATA hard disk drive - 5,400 RPM, 9.5-mm, 2.5-inch (raw drive)
669300-001
500GB SATA hard disk drive - 5,400 RPM, 9.5-mm, 2.5-inch (raw drive)
669299-001
320GB, SATA hard disk drive - 5,400 RPM, 9.5-mm
622643-001
Hard drive hardware kit, includes:
686261-001
2a
Hard drive bracket
2b
Hard drive connector cable
Hard drive bracket screws (not illustrated)
3
DVD±RW double-layer with SuperMulti drive (includes optical drive bezel and optical drive bracket)
686268-001
Miscellaneous parts
Component
Spare part number
65 W HP Smart AC adapter (RC, V, EM, 3-wire)
609939-001
Power cord (3-pin, black, 1.83 m)
For use in Denmark
490371-081
For use in Europe
490371-021
For use in Israel
490371-BB1
For use in Italy
490371-061
For use in North America
490371-001
For use in South Africa
490371-AR1
490371-111
For use in the United Kingdom and Singapore
490371-031
Screw kit
686278-001
Sequential part number listing
Spare part number
490371-001
Power cord for use in North America (3-pin, black, 1.83 m)
490371-021
Power cord for use in Europe (3-pin, black, 1.83 m)
490371-031
Power cord for use in the United Kingdom and Singapore (3-pin, black, 1.83 m)
490371-061
Power cord for use in Italy (3-pin, black, 1.83 m)
490371-081
Power cord for use in Denmark (3-pin, black, 1.83 m)
490371-111
Power cord for use in Switzerland (3-pin, black, 1.83 m)
490371-AR1
Power cord for use in South Africa (3-pin, black, 1.83 m)
490371-BB1
Power cord for use in Israel (3-pin, black, 1.83 m)
593553-001
593554-001
609939-001
65 W HP Smart adapter (RC, V, non-PFC, 3-wire)
622643-001
320GB, 5400-rpm, 9.5-mm hard drive (does not include hard drive bracket, hard drive connector cable, or screws)1
634250-001
750GB, 5400-rpm, 9.5-mm hard drive (does not include hard drive bracket, hard drive connector cable, or screws)1
641369-001
4GB memory module (PC3, 12800, 1600-MHz)
646125-001
Keyboard for use in the United States (includes keyboard cable)
646125-031
Keyboard for use in the United Kingdom and Singapore (includes keyboard cable)
646125-041
Keyboard for use in Germany (includes keyboard cable)
646125-051
Keyboard for use in France (includes keyboard cable)
646125-061
Keyboard for use in Italy (includes keyboard cable)
646125-071
Keyboard for use in Spain (includes keyboard cable)
646125-131
Keyboard for use in Portugal (includes keyboard cable)
646125-141
Keyboard for use in Turkey (includes keyboard cable)
646125-161
Keyboard for use in Latin America (includes keyboard cable)
646125-171
Keyboard for use in Saudi Arabia (includes keyboard cable)
646125-211
Keyboard for use in Hungary (includes keyboard cable)
646125-221
Keyboard for use in the Czech Republic (includes keyboard cable)
646125-251
Keyboard for use in Russia (includes keyboard cable)
646125-261
Keyboard for use in Bulgaria (includes keyboard cable)
646125-A41
Keyboard for use in Belgium (includes keyboard cable)
646125-B31
Keyboard for use in the Netherlands (includes keyboard cable)
646125-BA1
Keyboard for use in Slovenia (includes keyboard cable)
646125-BB1
Keyboard for use in Israel (includes keyboard cable)
646125-BG1
Keyboard for use in Switzerland (includes keyboard cable)
646125-DB1
Keyboard for use in Canada (includes keyboard cable)
646125-DH1
Keyboard for use in Denmark, Finland, and Norway (includes keyboard cable)
646125-DJ1
Keyboard for use in Greece (includes keyboard cable)
652972-001
2GB memory module (PC3, 12800, 1600 MHz)
653340-001
Intel Core i3-2350M 2.30 GHz processor (3.0MB L3 cache, dual core, 35 W; includes replacement thermal material)
655795-001
657325-001
664662-001
Intel Pentium B960 TJ85 2.20 GHz processor (2.0MB L3 cache, dual core, 35 W; includes replacement thermal material)
669299-001
500GB, 5400-rpm, 9.5-mm hard drive (does not include hard drive bracket, hard drive connector cable, or screws)1
669300-001
640GB, 5400-rpm, 9.5-mm hard drive (does not include hard drive bracket, hard drive connector cable, or screws)1
670691-001
675794-001
676785-001
Intel Pentium B970 TJ85 2.30-GHz processor (2.0MB L3 cache, dual core, 35 W; includes replacement thermal material)
677152-001
Intel Core i3-2370M 2.40-GHz processor (3.0MB L3 cache, 35 W; includes replacement thermal material)
677153-001
Intel Celeron DC B815 1.60-GHz processor (2.0MB L3 cache, dual core, 35 W; includes replacement thermal material)
680645-001
Intel Core i5-3210M 2.50-GHz processor (3.0MB L3 cache, 35 W; includes replacement thermal material)
682417-001
Intel Core i3-3110M 2.30-GHz processor (3.0MB L3 cache, 35 W; includes replacement thermal material)
686249-001
686253-001
Base enclosure
686254-001
Display bezel
686256-001
686257-001
686258-001
686259-001
686260-001
686261-001
Hard drive hardware kit (includes hard drive bracket, hard drive connector cable, and screws)
686262-001
686268-001
686269-001
686270-001
686271-001
686272-001
Cover kit (includes hard drive compartment cover and memory module/wireless module compartment cover)
686274-001
RTC battery
686275-001
Display rubber kit (includes display assembly rubber bumpers)
686276-001
Rubber feet kit (includes front and rear rubber feet)
686278-001
Screw kit
686279-001
686285-001
687698-001
Display enclosure
687700-001
687701-001
System board for use on computer models equipped with the HM75 Express chipset and an Intel Core i5 or i3 processor (includes replacement thermal material)
687702-001
System board for use on computer models equipped with the HM70 Express chipset and an Intel Pentium or Celeron processor (includes replacement thermal material)
687703-001
690019-001
Atheros AR9565 802.11b/g/n 1×1 WiFi + Bluetooth 4.0 combo adapter
690020-001
Ralink RT3290LE 802.11b/g/n 1×1 WiFi and Bluetooth 4.0 combo adapter
690536-001
Intel Celeron DC B730 1.80-GHz processor (2.0MB L3 cache, dual core, 35 W; includes replacement thermal material)
690537-001
Intel Celeron DC B820 1.70-GHz processor (2.0MB L3 cache, dual core, 35 W; includes replacement thermal material)
691415-001
693542-001
Intel Core i3-2308M 2.10-GHz processor (3.0MB L3 cache, 35 W; includes replacement thermal material)
1. The hard drive bracket, hard drive connector cable, and screws are included in the Hard Drive Hardware Kit, spare part number 686261-001.
