HP Scanjet Enterprise 8500 fn1 Document Capture Workstation - Solve problems checklist
Simple issues such as smudges on the scanning glass or loose cables can cause your product to produce fuzzy scans, operate in an unexpected manner, or fail to operate. Always check the following items when you encounter scanning problems.
  • If scans are fuzzy, check to see if the scanning strip to the left of the scanning glass is dirty or smudged. If so, clean the scanning strip.
    If you are scanning a document that will be analyzed using Optical Character Recognition (OCR), make sure that the original document is clear enough to be analyzed.
  • Make sure that the Ethernet and power cables are firmly seated in their respective connectors on the back of the product, and that the power cord is plugged into a working electrical outlet or surge protector.
  • Ensure that the product is receiving power.
    • Check that the green LED on the power supply case is on.
    • If the green LED is not on, ensure that power is available to the power outlet or surge protector that the power supply is plugged into.
    • If power is available to the power outlet or surge protector but the green LED is still not on, the power supply might be defective.
  • Make sure that the power LED and heartbeat LED on the formatter are functioning correctly.
  • Make sure that the product buttons are enabled.
  • Press and hold the power button for 10 seconds to turn off the product, wait 30 seconds, and then press the Power button again to turn on the product.
  • Make sure the automatic document feeder (ADF) hatch is closed.
  • Verify that the product is connected to the LAN, and that the product is correctly configured to use the network.
If you continue to have problems, it is possible that the firmware or associated drivers are out of date or have become corrupted. Go to www.hp.com/support to locate firmware and driver updates for the product.
