    Looking for Site Help?
HP Scanjet Enterprise 8500 fn1 Document Capture Workstation - Replace the keyboard
You can order keyboards in several languages as accessories.
To replace the keyboard, follow these steps:
  1. Press the Power () button to turn off the product, and then disconnect the power cord.
  2. Remove the keyboard.
    1. Slide the four sliding tabs toward the front of the product to release the keyboard, and then gently lift the keyboard up and away from the keyboard frame.
        Figure : Remove the keyboard
        Image: Remove the keyboard
      1. Slide the sliding tabs
      2. Lift the keyboard up and away from the keyboard frame
    2. Gently squeeze the edges of the cable connector to release the keyboard cable, and then set the keyboard aside.
      Figure : Disconnect the keyboard ribbon cable
      Image: Disconnect the keyboard ribbon cable
  3. Insert the new keyboard.
    1. Connect the new keyboard cable by gently squeezing the edges of the cable connector and pressing the connector down.
      Figure : Connect keyboard ribbon cable
      Image: Connect the keyboard ribbon cable
    2. Position the new keyboard over the keyboard frame so the fixed tabs on the keyboard align with the tab slots on the frame, gently push the keyboard against the keyboard frame, and then slide the four sliding tabs to secure the keyboard.
        Figure : Position and secure keyboard
      1. Align the fixed tabs of the keyboard to the keyboard frame
      2. Gently push the keyboard against the keyboard frame
      3. Slide the sliding tabs
  4. Reconnect the power cord, and then press the Power () button to turn on the product.
Country: Flag Vietnam
