HP Presentation Barcode Scanner - Overview
Product description
The HP Presentation Barcode Scanner is a general purpose on-counter presentation scanner designed for hands-free operation and easy fixed-location scanning. Its sleek, compact design utilizes imaging technology and can read 1D and 2D barcodes and codes presented from mobile devices, and capture images if the retailer requires photos on file.
Product features
Feature
Model
QY439AA
Scanner type
Imager
Light source
LEDs
Interface/Connection cable
USB
Nominal working distance
  • Depth of field: Minimum distance determined by symbol length and scan angle. Printing resolution, contrast, and ambient light dependent.
  • 1D linear codes:
    • 5 mils: 0 to 2.5 cm (0 to 1.0 in)
    • 7.5 mils: 0 to 8.2 cm (0 to 3.25 in)
    • 10 mils: 0 to 12.7 cm (0 to 5.0 in)
    • 13 mils UPC: 0 to 15.2 cm (0 to 6.0 in)
  • 2D linear codes:
    • 6.6 mils PDF: 3.8 to 7.6 cm (0 to 3.0 in)
    • 10 mils Data Matrix: 0.64 to 3.1 cm (0.25 to 1.25 in)
    • 10 mils PDF: 0 to 12.7 cm (0 to 5.0 in)
    • 15 mils PDF: 0 to 15.2 cm (0.0 to 6.0 in)
    • 24 mils Data Matrix: 0 to 12.7 cm (0 to 5.0 in)
Print contrast
25% minimum reflectance
Roll (tilt)
± 0° to 360°
Pitch
± 60°
Skew
± 60°
1D/2D decode symbologies1
Factory default barcodes
  • CODE 128
  • CODE 39
  • CODE 93
  • DataMatrix
  • EAN-13
  • EAN-8
  • GS1 DataBar Expanded
  • GS1 Databar Omnidirectional
  • PDF417
  • UPC-A
  • UPC-E
1: HP factory setting has these code selection enabled by default.
Software overview
Feature
Drivers
Windows UBB HID-KB and OPOS & JPOS (via USB-COM mode drivers)
Operating Systems (Compatible with)
  • Genuine Windows Vista Business 32
  • Genuine Windows XP Professional
  • Genuine Windows Embedded for Point of Service (WEPOS)
  • Genuine Windows Embedded POSReady 2009
  • Genuine Windows Embedded POSReady 7 32 bit
  • Genuine Windows Embedded POSReady 7 64 bit
  • Genuine Windows 7 Business 32
  • Genuine Windows 7 Business 64
Links to product QuickSpecs
Direct links to the QuickSpecs will be added as soon as they become available.
