This document contains steps to make sure that a new cartridge is compatible with your HP product, and to replace an old cartridge with a new one.
- ${title}
- ${title}
- ${title}
- ${title}
HP Officejet 150 Mobile All-in-One Printer Series (L511) - Replacing the Cartridges
Replacing cartridges
Follow these steps to replace a cartridge.
Step one: Check cartridge compatibility
Before you unpack a new cartridge, make sure that it is compatible with your HP product.
Step two: Replace the old cartridge
Press the Power button (
) to turn on the product.
Open the front access cover. Wait until the carriage is idle and silent before proceeding.Figure : Open the front access cover
Lift the cartridge latch, and then gently remove the cartridge from the carriage.Figure : Remove the cartridge
Remove the new cartridge from its package, and then pull the pink tab to remove the protective tape.
Do not touch the copper contacts on the rear of the cartridge or the ink nozzles on the bottom of the cartridge. Touching the contacts or the nozzles might damage the cartridge.Figure : Remove the protective tape from the cartridge -
Insert the cartridge at a slight angle into the carriage slot.
Place the tri-color cartridge in the left slot and the black or photo cartridge in the right slot.Figure : Insert the cartridge -
Close the cartridge latch. Press the latch down to make sure that it rests flat on the cartridge.Figure : Close the cartridge latch
Close the front access cover, and then allow the cartridge initialization process to complete before proceeding.Figure : Close the front access cover
Step three: Align the new cartridge
Use one of the following methods to align the cartridges.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
