HP LD4730/LD4730G 47-inch Micro-Bezel Video Wall Display - Overview
Product description
HP LD4730 and LD4730G 47-inch Micro-Bezel Video Wall Displays are perfect for large video wall installations designed to attract attention. They include stunning display technology and performance features and a micro-thin bezel that is virtually invisible between tiled displays adding visual appeal.
Product features
Feature
Spare part number
  • HP LD4730 47-inch Micro-Bezel Video Wall Display (head only): 647127-001
  • HP LD4730G 47-inch Micro-Bezel Video Wall Display (head only): 647124-001
Type
Wide-Aspect Active Matrix Thin Film Transistor (TFT)
Protective glass1
High impact, strengthened Corning Gorilla glass
119.4 cm (47 in) widescreen; diagonally measured
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
User programmable modes
Yes, 10
Anti-glare
Yes
Anti-static
Yes
Tilt range
None
Swivel range
None
Height adjustable
None
Response time (typical)2
  • 30 ms (On/Off)
  • 12 ms (gray to gray)
Pivot rotation
None
Base (feet)
Display stand kit sold separately
1: Applicable for LD4730G model only.
2: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
