HP Designjet L26500 Printer Series - Take-up reel does not wind
Predictably, if the take-up reel is not winding as anticipated, the printed output is likely to end up on the floor. If the printer recognizes a problem with the take-up reel, it interrupts the print job until the issue is corrected. If the printer does not recognize a problem, the job continues to print. The following table highlights possible issues and solutions.
Take-up reel LED status
Issue
Print job interrupted?
Possible cause
Possible solution
Blinking quickly
Take-up reel is not winding
Yes
The sensor beam was blocked for more than 3 seconds.
Make sure that the take-up reel sensors are not blocked by a strip of substrate or any objects. See the following graphic. Make sure that the collection bin is placed behind the foot brace.
Also ensure that the take-up reel power switch is in the On position.
Blinking slowly
No
The sensor cables are loose or unplugged.
Ensure that the sensor cables are correctly secured.
Solid red
No
There is too much resistance on the take-up reel motor.
Ensure that the substrate is not winding too tightly. A loop-shaping core should be inserted and hanging as shown in the User's guide.
Solid green
No
The take-up reel power switch is in the Off position
Ensure that the take-up reel power switch is in the On position.
Solid green
Take-up reel is winding in the wrong direction
No
The take-up reel wind-direction switch is in the wrong winding position.
After 3 seconds, the printer recognizes the problem and interrupts the print job. See the first error listed in this table.
Flip the take-up reel wind-direction switch to the correct position.
The following graphic shows the take-up reel sensors and cable.
  1. Take-up reel sensor
  2. Take-up reel sensor and cable housing unit
Country: Flag Vietnam
