Specification
Dimensions (H x W x D)
Unpacked with stand:
Unpacked without stand (head only):
Packaged:
Base area (footprint):
Head only:
Unpacked:
Packed:
Tilt range
0° to +25°
Swivel range
None
Height adjustable
None
Pivot rotation
None
Base and column
Both attachable, ships detached
- ${title}
- ${title}
- ${title}
- ${title}
HP 2311gt 23-inch LED Backlit 3D Monitor - Specifications
Physical specifications
Panel specifications
Feature
Type
Twisted Nematic (TN) LED Backlit LCD
Viewable image area
(diagonal)
58.4 cm (23.0 in) widescreen; diagonally measured
Screen opening
(H x W)
28.64 x 50.92 cm (11.28 x 20.05 in)
Aspect ratio
16:9
Viewing angle (typical)1
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Viewing angle (3D)1
Up to 12° vertical
Brightness (typical)1
2D mode:
3D mode:
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio
3,000,000:1 (in 2D)
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.265 mm
Backlight lamp life
(to half brightness)
30,000 hrs (minimum)
Color gamut (typical)1
72%
Color support2
Display up to 16 million colors
note: |
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
Menu, Minus (-), Plus (+), OK, Power button (Auto Adjustment, Source Control and Viewing Mode are hot-keys)
Languages
English, Spanish, French, Portuguese, Russian, Simplified Chinese, Traditional Chinese, Korean, German, Japanese
User controls
Brightness, Contrast, Color, Image Control, OSD Control, Management, Language, Information, Factory Reset, Source Control, Exit
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
Preset VESA graphic modes (non-interlaced)
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
Yes (20)
Anti-glare
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors1
One VGA (analog); one DVI-D; one HDMI
USB
Five USB downstream ports and one USB upstream port
Video cable
One HDMI
VGA cable length
1.8 m (5.9 ft)
Audio cable length
Not applicable
Audio
None
Input impedance
75 ohms ± (VGA)
Sync input
TTL separate sync
note: |
Power specifications
Specification
Input power
100 - 240 V ac, 50/60 Hz
Typical power consumption
36 W
Maximum
45 W
Power saving
< 0.5 W (sleep mode)
Power cable length
1.8 m (5.9 ft)
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C (102°F) maximum wet-bulb
Operating altitude
0 to 3,658 m (0 to 16,404 ft)
Non-operating altitude
0 to 12,192 m (0 to 40,000 ft)
Link to product overview information
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
