    Fix HP Printer issue on macOS
HP TouchSmart 610 Series Desktop PC - Using an HDMI Game Console or HDMI Video Player with your TouchSmart PC
This document applies to HP TouchSmart 610 series desktop computers.
You can use your Touchsmart PC as a monitor for playing games or viewing movies from devices that display HDMI or composite video, such as XBox or a Blue-ray movie player. To do this, you connect an HDMI-compliant game console to the TouchSmart using an HDMI cable. The TouchSmart HDMI ports are located on the right side of the computer, at the bottom.
Figure : HDMI cable connectors
Figure : HDMI ports
HDMI ports
The TouchSmart provides audio from the internal speakers, or you can use headphones or external speakers that are connected to the A/V source connector (audio out) located at the back of the computer.
Figure : A/V source connector
When the system is in Display mode, the computer is still running in the background. The keyboard, mouse, and touch screen are active and still control the computer. To avoid making unwanted changes to open files on your computer, it is recommended that you save and close all files before connecting to the HDMI ports.
When connected to the game console ports, your system is in display mode and has no recording capability.
After connecting the game console to the computer, use the Picture in Picture (PIP) software to:
  • select the incoming video source.
  • select the gaming mode.
  • adjust the brightness, contrast, color, and volume.
Connecting a game console to the computer
  1. Insert one end of the HDMI cable into the game console.
  2. Insert the other end of the HDMI cable into the HDMI ports on the computer.
  3. If you are using external speakers, connect the audio cable for the speakers to the A/V source connector.
  4. To switch between a full screen and a partial screen, double-click the gaming image on the screen.
  5. To open PIP, click Start, and then select All Programs, HP, and then select HP Picture in Picture.
    Figure : Opening HP Picture in Picture
    Clicking the PIP icon located on the desktop or in the system tray also opens the PIP application.
    The PIP options display.
    Figure : PIP options
    PIP options
  6. Click the video input: HDMI 1 (1) or HDMI 2 (2).
    Click the appropriate video input button (either HDMI 1 or HDMI 2) to toggle between full screen video and PIP.
  7. Click the video mode: Gaming (3), Default (4), Movie (5), or Text (6).
  8. Click Brightness (7), Contrast (8), Gamma (color) (9), or Volume (10), and then move the slider (11) up or down to make the adjustment.
  9. To check for updates to the PIP software, click the ✓ button (12).
Using the remote control in gaming mode
Use the A/V source button on your remote control to toggle between the two source modes: PC mode and gaming mode. If you use the remote control while you are in gaming mode, the following buttons still affect PC mode:
  • A/V — Switches between sources (PC or Gaming).
  • Volume — Adjusts the volume of the PC and the game console.
  • Mute — Mutes sound in games and on the PC.
  • Media Center (Start) — Automatically switches back to computer and opens the Media Center.
  • Power — Places the system into Sleep mode.
Returning to PC mode from gaming mode
Use any of the following methods to return to PC mode from gaming mode:
  • Click on the screen or left-click the mouse to return to the desktop.
  • Press the Esc key to return to the desktop.
  • Press the Ctrl, Alt, Del buttons simultaneously on the keyboard.
  • Press the Power/Sleep button on the keyboard or on the remote control.
  • Press the Power/Sleep button on the computer.
  • Press the Media Center (Start) button on the remote control.
Troubleshooting while in gaming mode
Issue
Solution
After connecting the game console to the ports on the computer, one of the following symptoms displays:
  • The screen keeps returning to PC mode.
    OR
  • A screen displays indicating the system is not receiving a signal.
  • Make sure that the device and the computer are turned on.
  • Make sure that the HDMI cable is connected from the game console to the computer.
  • Make sure that the correct source is highlighted on the PIP menu.
A No Signal message appears on the display.
  • Make sure that the device is turned on.
  • Make sure that the HDMI source selected on the PIP menu matches the HDMI connector on the side of the computer.
Audio drops when playing a video game.
  • The system is on Mute. Press the Volume + or Volume – button on the side of the computer to get out of Mute state.
  • Check the volume setting on the PIP menu.
  • Open the Audio Settings menu from within the gaming application and make sure that the correct audio format output is selected.
    Choose Digital Stereo, or PCM Audio. (HP TouchSmart PC does not support AC3, DTS, or Dolby Digital 5.1.)
After connecting external speakers, the audio is muted.
When an Audio Line Out connector (such as headphones or external speakers) is connected, the internal speakers are muted. Make sure that the volume on the external speakers is turned up.
