Specification
Dimensions (H x W x D)
Unpacked with stand:
Unpacked without stand (head only):
Packaged:
Base area (footprint):
Head only:
Unpacked:
Packed:
Tilt range
-5° to +15°
Swivel range
None
Height adjustable
None
Pivot rotation
None
Base
Detachable base
- ${title}
- ${title}
- ${title}
- ${title}
HP 1912nm 18.5-inch Internet Monitor - Specifications
Physical specifications
Panel specifications
Feature
Type
Twisted Nematic (TN) Type Cold Cathode Florescent (CCFL) Backlit LCD
Viewable image area
(diagonal)
47.02 cm (18.51 in) real diagonal widescreen; diagonally measured
Screen opening
(H x W)
23.04 x 4.09 cm (9.07 x 1.61 in)
Aspect ratio
16:9
Viewing angle (typical)1
Up to 90° horizontal/50° vertical
Brightness (typical)1
200 nits (cd/m²)
Contrast ratio (typical)1
600:1
Dynamic contrast ratio
None
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.30 mm
Pixels Per Inch (PPI)
85
Backlight lamp life
(to half brightness)
39,000 hrs (minimum)
Color gamut (typical)1
60%
Color depth1
16 million colors
note: |
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
Power, Menu, Minus (-), Plus (+), Mode Switch
Languages
Deutsch, Simplified Chinese, Traditional Chinese, Japanese, English, Espanola, Francis, Italian, Nederland, Portuguese
User controls
Picture, OSD, Display Setting, Other Settings, Information
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 83 kHz
Vertical frequency
48 to 76 Hz
Native resolution
1366 x 768 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
Text mode
640 x 480 @ 60 Hz or 720 x 400 @ 70 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog)
USB
Five USB downstream ports and one USB upstream port
Video cable
Not included
VGA cable length
Not applicable
Audio cable length
1.8 m (5.9 ft)
Audio
Built-in speakers
Input impedance
75 ohms
Sync input
TTL separate sync
Card reader
Power specifications
Specification
Input power
100 - 240 V ac, 47 or 63 Hz
Typical power consumption
45 W
Maximum
60 W
Power saving
< 1 W (sleep mode)
Power cable length
1.8 m (5.9 ft)
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C (102°F) maximum wet-bulb
Operating altitude
0 to 3,658 m (0 to 16,404 ft)
Non-operating altitude
0 to 12,192 m (0 to 40,000 ft)
Link to product overview information
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
