    We are upgrading our website
    Fix Windows 10 Update Issues
HP Notebook PCs - Switchable Graphics on Notebooks Configured with Intel and ATI GPUs
This document contains information pertaining to specific HP notebook PCs configured with dual Intel and AMD graphics adapters.
Notebook computers with a switchable graphics feature have two graphics processing units (GPUs) - a power-saving, integrated GPU and a high-performance, discrete GPU. Computers with an Intel power-saving GPU and an ATI high-performance GPU combine the low power advantages of an integrated GPU with the maximum performance of a discrete GPU. Use this document to understand the difference between Dynamic and Fixed Mode switchable graphics and to learn how to use and configure switchable graphics on computers with dual Intel and ATI GPUs.
Understanding Dynamic and Fixed Mode switchable graphics
Depending on the model, HP computers with Intel and ATI switchable graphics will operate in one of two modes: Dynamic Mode or Fixed Mode. Earlier models supported Fixed Mode while later models support Dynamic Mode. Using the Fixed Mode drivers on a computer that supports Dynamic Mode will not work. Using Dynamic Mode drivers on a computer that supports Fixed Mode switchable graphics will not work. For the best performance in all configurations, keep your graphics drivers and software updated. See Obtaining Software and Drivers for more information.
You can determine whether your computer has Dynamic Mode or Fixed Mode switchable graphics by reviewing the available options on the Catalyst Control Center software switchable graphics screen. Read a section below for more information.
Information and graphics contained in this document are current at publication. Your Catalyst Control Center Software graphics may be different due to differing versions of the software.
Using Dynamic Mode switchable graphics with default settings
By default, a computer with Dynamic Mode switchable graphics uses the integrated, or power-saving, GPU for most applications. The computer will automatically switch to the discrete, or high-performance, GPU when an application requires more performance. Customers can configure which applications require the high-performance GPU by selecting the application in the Catalyst Control Center software. When an application is configured to use the high-performance GPU, the computer switches graphics solutions when the application is started or closed.
Changing Dynamic Mode switchable graphics default settings
On computers with an Intel power-saving GPU and an ATI high-performance GPU, Dynamic Mode switchable graphics is configured using the Catalyst Control Center software. If you do not have this software, or if you previously uninstalled it, see Obtaining Software and Drivers to learn how get the latest version.
To maximize the energy efficiency or if you typically use programs that have lower graphical requirements (such as word processing or spreadsheet programs), you do not need to make any changes to the settings in the Catalyst Control Center software. The computer uses the power-saving GPU by default for most applications. You can still run high-performance programs, videos, and games in default mode but you are likely to notice lower frame rates, dropped frames, and choppy animations and transitions.
Applications that have higher graphical requirements (such as 3D video games), work better using the high-performance GPU. Graphics intensive software, videos, and games run at their optimum settings using the high-performance GPU.
Using the high-performance GPU on battery power will shorten the battery's effective usage time. The high-performance GPU generates a noticeable amount of heat while running graphics intensive software and, to keep the computer from overheating, the fan noise increases with increased fan use.
To change the default switchable graphics settings in the Catalyst Control Center software, follow the steps below.
  1. Click Start, type CCC in the Search field, and then select and open CCC from the search results list.
  2. Click the Start logo in the lower-left corner.
    On the Catalyst Control Center screen, click Power.
    Figure : Catalyst Control Center - Home
    Image of the Home screen with Power highlighted
  3. Then click Switchable Graphic Application Settings.
    Figure : Catalyst Control Center showing the available Power settings
    Image of the Home screen with Switchable Graphics highlighted
  4. Select a Recent Application and click Not Assigned (unless this has been altered before). Then choose either High performance, Power saving, or Based on power source.
    To add an application not shown in the Recent Applications list, click Add Application.
    Figure : Catalyst Control Center - Switchable Graphics Application Settings
    Catalyst Control Center Switchable Graphics window
  5. Click Apply to save the new settings.
    The changes take place immediately.
Dynamic Mode switchable graphics: OpenGL applications cannot be configured to use the discrete GPU
When configuring the Dynamic Mode switchable graphics in the Catalyst Control Center, some computers do not permit any OpenGL applications to be associated with the discrete, or high-performance, GPU. The OpenGL applications will work using the integrated, or power-saving, GPU, but performance levels may be lower than expected. HP has released an updated BIOS and AMD Graphics driver to enable Fixed Mode switchable graphics functionality for certain models originally configured with Dynamic Mode switchable graphics.
To find more information about the OpenGL limitations and to obtain the updated BIOS and driver see OpenGL Applications Cannot Be Configured to Use the Discrete GPU.
Using Fixed Mode switchable graphics with default settings
A computer with Fixed Mode switchable graphics default settings automatically prompts to switch between the high-performance and power-saving GPU when the power source changes. Read one of the following sections for more information.
Changing Fixed Mode switchable graphics default settings
The default switchable graphics settings can be changed in the Catalyst Control Center software installed on your computer. If you do not have this software, or if you previously uninstalled it, see Obtaining Software and Drivers to learn how get the latest version.
Available options in the Catalyst Control Center software vary based on whether the computer is on external power (AC adapter connected) or on battery power (AC adapter disconnected). Read a section below for more information.
