    Fix HP Printer issue on macOS
HP LaserJet Enterprise 600 M601, M602, and M603 Series Printer - Clean the product
To clean the product exterior, use a soft, water-moistened cloth.
Clean the paper path
  1. At the product control panel, press the Home button.
  2. Open the following menus:
    • Device Maintenance
    • Calibrate/Cleaning
  3. Select the Print Cleaning Page item, and press the OK button to print the page.
  4. The cleaning process can take several minutes. When it is finished, discard the printed page.
