HP LD4720tm 47-inch LCD Interactive Digital Signage Display - Overview
Product description
HP LD4720tm 47-inch LCD Interactive Digital Signage Display includes a factory-integrated touch screen with an innovative No-Ghosting technology that provides more accurate touch recognition. The integrated IR technology allows for a more narrow bezel so the multi-monitor display presents a more natural image when matrixed together.
Product features
Feature
Type
Wide-Aspect Active Matrix Thin Film Transistor (TFT)
119.4 cm (47 in) widescreen; diagonally measured
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
User programmable modes
Yes, 10
Anti-glare
Yes
Anti-static
Yes
Tilt range
None
Swivel range
None
Height adjustable
None
Response time (typical)1
9 ms
Pivot rotation
None
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
