HP ZR2040w 20-inch LED Backlit IPS Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked with stand:
  • 35.8 × 48.2 x 13.6 cm (14.1 x 18.97 x 3.35 in)
Unpacked without stand (head only):
  • 29.41 × 48.2 x 4.75 cm (11.58 x 18.97 x 1.87 in)
Packaged:
  • 42.2 × 55.2 x 12.8 cm (16.6 x 21.7 x 5.0 in)
Base area (footprint):
  • 23.63 × 15.11 cm (9.30 x 5.95 in)
Unpacked:
  • 3.8 kg (8.36 lb)
Packaged:
  • 5.4 kg (11.88 lb)
Head only:
  • 3.1 kg (6.82 lb)
Tilt range
-5° to +30°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Detachable stand
Stand ships detached and attaches easily with a one-click assembly.
Signal interface/performance
Specification
Horizontal frequency
50 to 76 kHz
Vertical frequency
24 to 83 Hz
Native resolution
1600 x 900 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/other Inputs
Specification
Plug and play
Yes
Input connectors
  • (1) DVI-D connector
  • (1) VGA connector
  • (1) DisplayPort connector (HDCP support on DVI and DisplayPort)
Input impedance
75 Ohms (VGA)
Sync input
TTL separate synch
Video cable
One DisplayPort and one 15-pin D-sub (VGA)
Video cable lengths
1.8 m (5.9 ft)
Audio
No
Audio cable length
N/A
Electrical specifications
Specification
Input power
100 – 240 V ac, 50 or 60 Hz
Energy star power1
24.5 W
Default power2
27 W
Maximum power consumption3
33 W
Power saving
<0.3 W sleep (standby)
Power cable length
1.9 m (6.2 ft)
1: Energy star power is measured with factory defaults, brightness at Energy Star level of 200 cd/m2 and with no USB loads.
2: Default power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
3: Maximum power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C max wet-bulb
Operating altitude
0 to 5,000 m (16,404 ft)
Non-operating altitude
0 to 12,192 m (40,000 ft)
White LED backlight
Yes
Mercury free
Yes
BFR/PVC free
Yes (everything except external cables)
Arsenic-free glass
Yes
