    Fix Windows 10 Update Issues
HP Notebook PCs - Setting up HP Setup Manager
HP Setup Manager helps you setup and explore some of the features included on your computer. It guides you step-by-step and provides direct links to important HP and Windows applications.
To launch HP Setup Manager, click Start, enter setup in the search field, and select HP Setup Manager from the list.
