HP ProBook 4730s Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP ProBook 4730s Notebook PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Tools required
  • Small, Phillips-head P1 screwdriver.
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
750GB SATA hard disk drive - 7,200 RPM, 2.5-inch form factor
633252-001 (Original)
Yes
640GB SATA hard disk drive - 5,400 RPM, 2.5-inch form factor (raw drive)
603785-001 (Modified)
Yes
500GB SATA hard disk drive - 7,200 RPM
634925-001 (Modified)
Yes
500GB SATA hard disk drive - 5,400 RPM
634638-001 (Modified)
Yes
320GB SATA hard disk drive - 5,400 RPM
622643-001 (Modified)
Yes
320GB SATA hard disk drive - 7,200 RPM
641672-001 (Modified)
Yes
250GB SATA hard drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height
635225-001 (Modified)
Yes
250GB SATA hard drive - 5,400 RPM, 2.5-inch form factor (raw drive)
622641-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the four 3-mm P1 Phillips-head screws that secure the hard disk drive to the base enclosure.
  3. Using the Mylar pull tab, slide the hard disk drive to the left to disconnect the hard disk drive from the hard disk drive connector.
  4. Lift and remove the hard disk drive from the base enclosure.
  5. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Lower the hard disk drive into the hard disk drive bay.
  3. Using the Mylar pull tab, slide the hard disk drive to the right to connect the hard disk drive to the hard disk drive connector.
  4. Replace the four 3-mm P1 Phillips-head screws that secure the hard disk drive to the base enclosure.
Parts return
