    Fix Windows 10 Update Issues
HP ProBook 4730s Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP ProBook 4730s Notebook PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
8-cell lithium-ion (Li-Ion), 2.55 Ah, 73 WHr
633807-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
  2. Slide the battery release latches towards the battery icons to disengage the battery.
  3. Remove the battery by lifting it out of the battery bay.
Battery replacement
  1. Lower the rear edge of the battery into the battery bay.
  2. Lower the front edge of the battery until it clicks into place.
Parts return
