HP EliteBook 2560p Notebook PC - Removing and Replacing the Real-Time Clock Battery
Real-time clock battery removal
Observe all precautions when removing and replacing components.
  1. Disconnect the RTC battery cable from the system board.
  2. Peel the RTC battery up from the adhesive that holds it in place on the system board.
Real-time clock battery replacement
  1. With the adhesive side down, place the RTC battery into position on the system board.
  2. Connect the RTC battery cable to the system board.
