HP EliteBook 2560p Notebook PC - Removing and Replacing the Processor
Processor removal
Observe all precautions when removing and replacing components.
  1.   note:
    Before removing the processor, take special note of the orientation of the gold triangle on a corner of the processor. The processor must be installed in the same orientation in which it was removed or it may be destroyed.
  2. Use a flat-bladed screwdriver to turn the processor locking screw one-half turn counterclockwise.
  3. Lift the processor to remove.
Processor replacement
  1. Remove the processor from the static dissipative bag.
    Align the gold triangle on the processor with the triangle on the socket. If the processor is not inserted correctly, it may be destroyed.
  2. Align the processor pins so that they fit freely into the socket.
  3. Turn the processor locking screw one-half turn clockwise to lock the processor.
Country: Flag Vietnam
