HP Compaq LA2206xc 21.5-inch Webcam LCD Monitor Specifications
Product description
HP Compaq LA2206xc 21.5-inch display comes with an integrated webcam, microphone, speakers, and height adjustable stand.
Product features
Feature
Type
TN (Twisted Nematic) LED Backlit LCD
54.61 cm (21.5 in) widescreen
Screen opening (W x H)
47.66 x 26.81 cm (18.76 x 10.56 in)
Aspect ratio
16:9
Viewing angle (typical)
  • Horizontal viewing angle: 170°
  • Vertical viewing angle: 160°
Brightness (typical)1
250 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
1,000,000:1
Response time (typical)1
5 ms (on/off)
Pixel pitch
0.248 mm
Backlight lamp life (to half brightness)
30,000 hours
Color gamut (typical)
68%
Color support
Can display up to 16.7 million colors with the use of FRC technology
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Signal interface/performance
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
200 MHz (VGA); 165 MHZ (DVI and DisplayPort)
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
Warm (6500 K)
Video/other Inputs
Specification
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
  • 75 Ohms (VGA)
  • 100 Ohms (DVI-D and DisplayPort)
  • 90 Ohms (USB)
Sync input
TTL separate synch
Video cable
  • (1) 15-pin D-sub (VGA)
  • (1) DVI-D to DVI-D
  • (1) USB cable
Video cable lengths
1.8 m (5.9 ft)
Audio
  • (2) 1 with channel built-in speakers (rear firing)
  • Audio jacks: Audio in (mic) Audio out (headphones/speakers)
  • (1) audio cable included
Audio cable length
1.8 m (5.9 ft)
Built-in 720p HD Webcam with dual mic and LED
USB
  • (2) USB ports
  • (1) USB cable included
USB cable length
1.8 m (5.9 ft)
Electrical specifications
Specification
Input power
100 – 240 V ac, 50 or 60 Hz
Typical power consumption
35 W
Maximum consumption
42 W
Power saving
<0.5 W standby; <0.5 W off
Power cable length
1.9 m (6.2 ft)
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked with stand:
  • 33.33 to 43.87 × 51.80 x 22.73 cm (17.68 x 5.59 x 13.39 in)
Unpacked without stand (head only):
  • 31.5 × 51.8 x 4.75 cm (12.40 x 20.39 x 1.87 in)
Packaged:
  • 15.4 x 58.1 x 46.8 cm (6.06 x 22.87 x 18.43 in)
Base area (footprint):
  • 22.71 x 24.84 cm (8.9 x 9.8 in)
Unpacked:
  • 6.1 kg (13.4 lb)
Packaged:
  • 8.3 kg (18.4 lb)
Head only:
  • 3.8 kg (8.4 lb)
Tilt range
-5° to +30°
Swivel range
Yes (+/- 360°)
Height adjustable
Yes - 0 to 13.0 cm (0 to 5.1 in)
Pivot rotation
Yes
Base
Detachable, ships attached
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C max wet-bulb
Operating altitude
+0 to 5,000 m (16,404 ft)
Non-operating altitude
0 to 12,192 m (40,000 ft)
White LED backlights
Yes
CCFL panel
No
Mercury free
Yes
BFR/PVC free
Yes (everything except external cables)
Arsenic-free glass
Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
