HP EliteBook 2560p Notebook PC - Removing and Replacing the Service Door
This document is provided to assist in removing and replacing the service door for the HP EliteBook 2560p Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the service door that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Bottom door
651373-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the service door, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Service door from the menu on the upper left hand side of the screen.
Click here to view the service door removal video (right-click on the link to open in a new window/tab).
Service door removal
Observe all precautions when removing and replacing components.
  2. Slide the service door release latch away from the center of the notebook, while pushing the service door towards the front of the notebook.
  3. Lift the service door and remove it.
Service door replacement
  1. Position the service door on the base enclosure with the rear hook visible.
  2. Slide the service door into position over the base enclosure until it clicks into place.
Country: Flag Vietnam
