    We are upgrading our website
HP ProBook 4530s Notebook PC - Removing and Replacing the Keyboard
This document is provided to assist in removing and replacing the keyboard for the HP ProBook 4530s Notebook PC.
Minimum skill level
The End user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Tools required
  • Small, Phillips-head (P1) screwdriver
Parts required
The replacement part number will vary depending on the keyboard that is being replaced. If a part is listed as "Yes" under "Requires return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part number
Requires return
Keyboard assembly - Full-sized keyboard with numeric keypad
646300-xx1 (Modified)
Yes
The part number will vary based on the country. Click here for a list of country-specific spare part numbers.
Summary of instructions
To view a video demonstrating the procedure for removing the keyboard, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Keyboard from the menu on the upper left hand side of the screen.
Click here to view the keyboard removal video (right-click on the link to open in a new window/tab).
Keyboard removal
  2. Remove the two 7-mm P1 Phillips-head screws identified with keyboard icons that secure the keyboard to the base enclosure.
  3. Using a probe tool, gently press into the keyboard opening, identified with a keyboard icon, until the keyboard releases from the top cover.
  4. Turn the notebook right side up and open the display panel fully.
  5. Using your finger or a flat bladed non-marring tool, gently lift up on the rear edge of the keyboard to disengage the keyboard from the top cover.
  6. Slide the keyboard towards the rear of the notebook to release the tabs at the front of the keyboard.
  7. Move the keyboard to the left and place it on the top cover.
    Do not lift the keyboard further away from the notebook than necessary to access the keyboard ribbon cable and ZIF connector.
  8. Gently lift up on the locking bar of the keyboard ZIF connector and remove the keyboard ribbon cable.
    Use care to prevent damaging the ZIF connector and ribbon cable.
  9. Remove the keyboard.
Keyboard replacement
  1. Place the keyboard on the top cover so that the keyboard ribbon cable and ZIF connector are accessible.
  2. Insert the keyboard ribbon cable into the ZIF connector on the system board and gently press down on the ZIF connector locking bar.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat until it engages with the top cover.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the two 7-mm P1 Phillips-head screws in the wireless LAN minicard compartment that secure the keyboard to the base enclosure.
