HP Compaq 6200 Pro Small Form Factor PC - Removing and Replacing the Memory
This document is provided to assist in removing and replacing the memory for the HP Compaq 6200 Pro Small Form Factor PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the memory that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
4GB, PC3-10600, DDR3-1333 MHz, 240-pins, non-ECC, unbuffered Dual In-Line Memory Module (DIMM)
585157-001 (Modified)
Yes
2GB, PC3-10600, DDR3-1333 MHz, 240-pins,non-ECC, unbuffered Dual In-Line Memory Module (DIMM)
635803-001 (Modified)
Yes
1GB, PC3-10600, DDR3-1333 MHz, 240-pins,non-ECC, unbuffered Dual In-Line Memory Module (DIMM)
635802-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory from the menu on the upper left hand side of the screen.
Click here to view the memory removal video (right-click on the link to open in a new window/tab).
The chassis and internal components of this computer are similar to the HP Compaq 6000 Pro Small Form Factor (SFF) Business PC and the HP Z210 Small Form Factor (SFF) Workstation. Removal and replacement procedures are the same. The above mentioned video link shows removal and replacement procedures for HP Z210 SFF Workstation.
Memory removal
  2. Pull up and hold the access panel release latch.
  3. Rotate the panel up and lift it away from the chassis.
  4. Rotate the drive cage to the up position.
  5. Push down and out on the memory socket latches to release the memory module.
  6. Pull the memory module up and out of the socket.
Memory replacement
  1. Ensure that the memory socket latches are pushed down and away from the memory socket.
  2. Match the notch on the memory module with the key on the memory socket.
  3. Push the module down firmly into the socket until the latches snap into place and the module is fully seated.
  4. Rotate the drive cage to the down position.
  5. Slide the lip on the front end of the access panel under the lip on the front chassis guide rail.
  6. Lower the back end of the panel until it contacts the chassis.
  7. Press down on the access panel until it locks into place.
Country: Flag Vietnam
