    Looking for Site Help?
Document ID: c02864855
Version: 1
HP Notebook PCs - Windows XP Does Not Support Switchable Graphics
Release date : 07-Jun-2011
Last updated : 20-Jun-2011
DESCRIPTION
The notebook does not support the Switchable Graphics feature while running the Microsoft Windows XP or Window Vista operating systems.
sourceInformation
SCOPE
HP ProBook 4330s Notebook PC
HP ProBook 4331s Notebook PC
HP ProBook 4430s Notebook PC
HP ProBook 4431s Notebook PC
HP ProBook 4530s Notebook PC
HP ProBook 4730s Notebook PC
RESOLUTION
The Windows 7 Starter edition, Windows Vista, and Windows XP operating systems do not support the Switchable Graphics feature. The Switchable Graphics feature only functions with Windows 7.
Although the discrete graphics adapter device drivers are not available for Windows XP and Windows Vista, the integrated graphics adapter device driver for the notebook can be updated.
Download one of the following SoftPaqs to update the integrated graphics adapter device driver. However, before installing either SoftPaq, first read the section Change the BIOS Settings (below).
Windows XP:
Softpaq Description
Download
Intel Video Driver and Control Panel
VERSION: 6.14.10.5337 REV: A
Windows Vista:
Softpaq Description
Download
VERSION: 8.15.10.2342 REV: B
Note: A more recent version of this software may be available. Check for updated drivers and software for your computer at http://www.hp.com.
Change the BIOS Settings:
The SoftPaqs for both Windows XP and Windows Vista can only be installed after you disable the Switchable Graphics feature in the notebook's BIOS.
If you install either SoftPaq without first disabling the Switchable Graphics feature in BIOS, they will not install properly and the integrated graphics adapter will not be updated.
To disable Switchable Graphics in BIOS:
  1. Turn on the notebook.
  2. During the first few seconds of startup, press the F10 key to enter BIOS Setup.
  3. Select the System Configuration tab.
  4. Select the Device Configurations option.
  5. Uncheck the Switchable Graphics option.
  6. Click Save, then Exit. The system will prompt you for confirmation.
After the notebook reboots, install the downloaded SoftPaq for the operating system.
Hardware platforms affected : HP ProBook 4330s Notebook PC, HP ProBook 4331s Notebook PC, HP ProBook 4430s Notebook PC, HP ProBook 4431s Notebook PC, HP ProBook 4530s Notebook PC, HP ProBook 4730s Notebook PC
Operating systems affected : Microsoft Windows XP Home Edition Microsoft Windows XP Pro 64-Bit Edition Microsoft Windows XP Professional Edition Microsoft Windows XP Tablet PC Edition
Support Communication Cross Reference ID : IA02864798
Country: Flag Vietnam
