HP Compaq 6200 Pro Microtower PC - Removing and Replacing the Access Panel
This document is provided to assist in removing and replacing the access panel for the HP Compaq 6200 Pro Microtower PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the access panel that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Side access panel
646825-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the access panel, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Access panel from the menu on the upper left hand side of the screen.
Click here to view the access panel removal video (right-click on the link to open in a new window/tab).
Access panel removal
  2. Loosen the two captive thumbscrews that secure the access panel to the chassis.
  3. Lift the access panel off the chassis.
Access panel replacement
  1. Slide the lip on the front edge of the access panel under the front chassis guide rail.
  2. Rotate the back end of the access panel against the chassis.
  3. Ensure that the panel is completely closed and tighten the two thumbscrews that secure the access panel to the chassis.
Country: Flag Vietnam
