    Fix HP Printer issue on macOS
HP EliteBook 2560p Notebook PC Product Specifications
Product features
Feature
Mobile Intel QM67 Express chipset
Graphics
Intel HD Graphics 3000 Microsoft DirectX 10.1 (Shader Model 4.1) and OpenGL 3.0 capable
Display1
Internal:
  • 12.5-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
  • Ambient Light Sensor
  • HP Privacy Filter support
External:
  • Up to 32-bit per pixel color depth
  • Display port supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz.
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
Memory2
Standard:
  • DDR3 PC3-10600 SDRAM (1333 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 2GB, 4GB, and 8GB SODIMMs
Maximum:
  • Upgradeable to 16GB with 8GB SODIMMs in slots 1 and 2
Dual channel:
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Communications
  • Integrated Intel 82579LM Gigabit3
  • Network Connection (vPro configurations) 56K V.92 modem4
Wireless devices
Mobile Broadband options5:
  • Two 850/900/1575/1700/1800/1900/2100 MHz antennas integrated in the top of the display panel support current and future WWAN technologies.
HP hs2340 HSPA+ Mobile Broadband module:
  • Integrated mobile broadband module
  • Connectivity to both HSPA and HSPA+ (UMTS) networks
  • Standalone, Internet and network assisted GPS functionality for various mapping applications and security applications
HP un2430 EV-DO/HSPA Mobile Broadband module:
  • Integrated mobile broadband module with Gobi global mobile Internet technology
  • Connectivity to both CDMA (EVDO) and UMTS (HSPA) networks
  • GPS functionality for various mapping applications and security applications
All 802.11 integrated wireless LAN options:
  • Wi-Fi certified6
  • Cisco Compatible Extensions support
  • Wired Equivalent Privacy (WEP) support up to 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Intel Centrino Ultimate-N 6300 (3 x 3):
  • Integrated support for 802.11a, b, g, and n6
  • 3 transmit, 3 receive antennas
  • Up to 450 Mb/s data rate
Intel Centrino Advanced-N 6205 (2 x 2):
  • 2 transmit, 2 receive antennas
  • Up to 300 Mb/s data rate
Broadcom 4313GN 802.11b/g/n WiFi adapter:
  • 1 transmit, 1 receive antenna
  • Up to 72 Mb/s data rate
Broadcom 43224AGN 802.11a/b/g/n (2 x 2) WiFi adapter:
  • Integrated support for 802.11 a, b, g, and n
HP Integrated Module with Bluetooth 2.1+EDR wireless technology:
  • Bluetooth Specification v2.1+EDR compliant
  • Works with a wide range of Bluetooth devices
Keyboard
  • 101/102-key compatible keyboard
  • International key layouts
  • Editing keys, both left and right control and alt keys, function keys, 19 x 19 mm key pitch (center-to-center spacing), 2.0 mm stroke, and comfort-dished keycaps
Pointing device
  • Touchpad with On/Off button, two-way scroll, gestures, two pick buttons
  • Pointstick with two additional pointstick buttons
Expansion card slots
ExpressCard/54 slot:
  • Supports ExpressCard/54
Integrated Smart Card Reader:
  • Compatible with ISO 7816 compliant Smart Cards
  • PC/SC interface support
Secure Digital/MMC slot:
  • Supports Secure Digital (SD), MultiMedia Card (MMC)
Internal storage
Hard drives7:
  • 250/320/500/750GB 7200 rpm SMART SATA II
  • 320GB 7200 rpm SMART SATA II Self Encrypting Drive
HP 3D DriveGuard (Windows only):
  • Reduces the transmission of shock to the hard drive
  • Uses three-axis digital motion detection with intelligent sensitivity
Solid State drive:
  • 128/160GB
Interfaces
  • External monitor: Two (one display port and one VGA port)
  • Combo headphone/microphone jack: One
  • Power connector: One
  • RJ-11/modem: One
  • RJ-45/Ethernet: One
  • USB 2.0: Two (including the charging port)
  • eSATA/USB 2.0 combo: One
  • Docking connector: For HP 2560 Series Docking Station
Audio
  • SRS premium sound
  • Integrated stereo speakers
  • Integrated dual-microphone array
  • Button for volume mute; function keys for volume up and down
Visual
Optional 720p HD webcam:
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 f/s
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Power supply
  • External 90-W Smart AC adapter
  • Power cord included: 1.8 m (6 ft)
  • Total length including external AC adapter: 3.66 m (12 ft)
  • HP Fast Charge8
Battery
Primary battery:
  • HP 9-cell (100 WHr) Li-Ion battery
  • HP 6-cell (62 WHr) Li-Ion battery
  • HP 3-cell 31 WHr Li-Ion primary battery
  • HP Long Life 6-cell (55 WHr) Li-Ion battery
Battery life9
9-cell (100 WHr):
  • Up to 14 hours and 15 minutes
6-cell (62 WHr):
  • Up to 8 hours and 30 minutes
HP 3-cell primary battery:
  • Up to 4 hours
1: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
2: Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires a Windows 64-bit operating system or Linux. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, so that above 3GB all memory may not be available due to system resource requirements.
3: The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
4: Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
5: Separately purchased mobile network operator service is required.
6: In countries where 802.11n is not allowed, this capability is not enabled (802.11a/b/g only).
7: These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 20GB is reserved for the system recovery software.
8: HP Fast Charge recharges your battery up to 90% within 90 minutes when the system is off. Fast Charge Technology does not apply to 9-cell primary batteries.
9: Battery life will vary depending on the product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery will naturally decrease with time and usage.
Physical specifications
Feature
Dimensions (H x W x D)
  • 27.4 x 305.2 x 209.0 mm (1.08 x 12.02 x 8.23 in)
  • 32.8 mm (1.29 in) height at rear
  • Starting at 1.67 kg (3.68 lb) with weight saver (no optical drive)
  • Starting at 1.75 kg (3.84 lb) with optical drive
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery and WLAN.
Software overview
Feature
Operating System (OS)
Preinstalled:
  • Genuine Windows 7 Professional 32
  • Genuine Windows 7 Home Premium 32
  • Genuine Windows 7 Home Basic 32 (select countries)
  • Genuine Windows 7 Professional 64
  • Genuine Windows 7 Home Premium 64
  • Genuine Windows Vista Home Basic 32
Supported:
  • Genuine Windows 7 Enterprise 32
  • Genuine Windows 7 Enterprise 64
  • Genuine Windows 7 Ultimate 32
  • Genuine Windows 7 Ultimate 64
  • Genuine Windows Vista Enterprise 32
  • Genuine Windows Vista Enterprise 64
  • Genuine Windows Vista Business 32
  • Genuine Windows Vista Business 64
  • Genuine Windows XP Professional 32
Certified:
  • SUSE Linux Enterprise Desktop 11
Preinstalled software with Windows Operating System (OS):
  • HP Recovery Manager
  • HP Support Assistant
  • HP ProtectTools Security Manager
  • HP ProtectTools for Central Management
  • HP Hotkey Support
  • HP QuickWeb
  • HP Power Assistant
  • HP Connection Manager 4.0
  • HP DayStarter
  • Microsoft Office 2010 preloaded (purchase of a Product   Key required to activate a full Office 2010 suite)1
  • Norton Internet Security 20112
  • PDF Complete Special Edition3
  • Intervideo WinDVD - DVD Player (select models)
  • Roxio Burn Secure (select models)
  • Roxio MyDVD 10 SE (select models)
  • HP Webcam Software (select models)
  • Skype
Additional software available from the web:
  • HP SoftPaq Download Manager
1: Microsoft Office 2010 Preloaded includes reduced functionality versions of Word and Excel. Purchase of Product Key required to activate full Office 2010 suite available at participating resellers/retailers. Click here to purchase of Product Key required to activate full Office 2010 suite available at participating resellers/retailers.
The above-mentioned web link will take to a non-HP web site. HP does not control and is not responsible for information outside of the HP web site.
2: Norton Internet Security 2011 includes 60 days of complimentary live updates; subscription required for live updates thereafter. Internet access required to receive updates.
3: PDF Complete Special Edition 60 day trial; purchase license afterwards for full functionality.
Electrical specifications
Feature
Stand-alone power requirements (AC power)
Nominal operating voltage
18.5 V
Maximum operating power
< 65 W
Environmental specifications
Feature
Temperature
Operating:
  • 0° to 35°C (32° to 95°F) (non-writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating:
  • -20° to 60°C (-4° to 140°F)
Relative humidity
Operating:
  • 10% to 90%, non-condensing
Non-operating:
  • 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating:
  • 125 G, 2 ms, half-sine
Non-operating:
  • 200 G, 2 ms, half-sine
Random vibration
Operating:
  • 0.75 g
Non-operating:
  • 1.50 g
Altitude (unpressurized)
Operating:
  • -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
  • -15.24 to 12,192 m (-50 to 40,000 ft)
Safety certifications
Feature
Industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • Energy Star: Select models1
  • EPEAT: Gold target2
  • ICES: Yes
  • GS: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KCC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT Yes GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
1: Configurations of the HP EliteBook 2560p Notebook PC that are Energy Star qualified are identified as HP EliteBook 2560p Notebook PC Energy Star on HP websites and on Energy star website. Click here to visit Energy Star website.
The above web link will take to a non-HP website. HP does not control and is not responsible for the information located outside the HP website.
2: EPEAT TBD Registered in U.S. EPEAT registration varies by country. Click here to see the registration status by country.
