HP Color LaserJet 2840 All-in-One Series Printer - Replace the Imaging Drum
Summary of introduction
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP LaserJet MFP and All-in-One Products under the Product family, and then select the printer model under the Product series category.
Imaging drum replacement
  1. Remove any media from the ADF, and then push the scanner-release button to open the scanner assembly.
  2. Open the cartridge door.
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
  4. Lift the imaging drum straight up to remove it from the device.
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins.
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers.
  8. Remove the orange cover from the imaging drum.
    Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer.
  10. Lower the imaging drum into the printer, and then press it firmly into place.
  11. Close the top cover and the scanner assembly.
  12. Run a print-quality test.
Country: Flag Vietnam
