HP Designjet T790 and T1300 ePrinter Series - How to order supplies and accessories
There are two alternative ways to order supplies or accessories for your printer:
The rest of this chapter lists the available supplies and accessories, and their part numbers.
Order ink supplies
The following ink supplies can be ordered for your printer.
Ink cartridges
Cartridge
Part number
HP 72 69 ml Photo Black Ink Cartridge
C9397A
HP 72 69 ml Cyan Ink Cartridge
C9398A
HP 72 69 ml Magenta Ink Cartridge
C9399A
HP 72 69 ml Yellow Ink Cartridge
C9400A
HP 72 69 ml Gray Ink Cartridge
C9401A
HP 72 130 ml Matte Black Ink Cartridge
C9403A
HP 72 130 ml Photo Black Ink Cartridge
C9370A
HP 72 130 ml Cyan Ink Cartridge
C9371A
HP 72 130 ml Magenta Ink Cartridge
C9372A
HP 72 130 ml Yellow Ink Cartridge
C9373A
HP 72 130 ml Gray Ink Cartridge
C9374A
HP 726 300 ml Matte Black Ink Cartridge (T1300 series only)
CH575A
Printheads
Printhead
Part number
HP 72 Gray & Photo Black Printhead
C9380A
HP 72 Magenta & Cyan Printhead
C9383A
HP 72 Matte Black & Yellow Printhead
C9384A
Order paper
The following paper types are currently provided for use with your printer.
This list is likely to change over the course of time. For the latest information, see http://www.hp.com/go/T790/accessories/ or http://www.hp.com/go/T1300/accessories/.
Paper types that HP does not support may nevertheless be compatible with your printer.
Key to availability:
  • (A) indicates papers available in Asia (excluding Japan)
  • (C) indicates papers available in China
  • (E) indicates papers available in Europe, the Middle East and Africa
  • (J) indicates papers available in Japan
  • (L) indicates papers available in Latin America
  • (N) indicates papers available in North America
If the part number is not followed by parentheses, the paper is available in all regions.
Roll paper
Paper type
g/m²
Length
Width
Part numbers
HP Bond and Coated Paper
HP Universal Bond Paper
80
45.7 m
594 mm (A1)
Q8003A (AJ)
610 mm
Q1396A
914 mm
Q1397A
1067 mm
Q1398A
91.4 m
594 mm (A1)
Q8004A (EAJ)
841 mm (A0)
Q8005A (EAJ)
HP Bright White Inkjet Paper
90
45.7 m
420 mm (A2)
Q1446A (J)
594 mm (A1)
Q1445A (EJ)
610 mm
C1860A (LN), C6035A (AEJ)
841 mm (A0)
Q1444A (EJ)
914 mm
C1861A (LN), C6036A (AEJ)
91.4 m
914 mm
C6810A
HP Recycled Bond Paper
80
45.7 m
420 mm (A2)
CG892A (E)
610 mm
CG889A (EN)
914 mm
CG890A (EN)
1067 mm
CG891A (EN)
HP Cockle-free Coated Paper
100
45.7 m
610 mm
CG883A (EN)
914 mm
CG884A (EN)
1067 mm
CG885A (EN)
HP Cockle-free Heavyweight Coated Paper
170
30.5 m
610 mm
CG886A (EN)
914 mm
CG887A (EN)
1067 mm
CG888A (EN)
HP Universal Coated Paper
95
45.7 m
610 mm
Q1404A (AEJN)
914 mm
Q1405A (AEJN)
1067 mm
Q1406A
HP Coated Paper
90
45.7 m
420 mm (A2)
Q1443A (J)
457 mm
Q7897A (EJN)
594 mm (A1)
Q1442A (EJ)
610 mm
C6019B
841 mm (A0)
Q1441A (EJ)
914 mm
C6020B
1067 mm
C6567B
91.4 m
914 mm
C6980A
HP Universal Heavyweight Coated Paper
120
30.5 m
610 mm
Q1412A (AEJN)
914 mm
Q1413A
1067 mm
Q1414A (AEJN)
HP Heavyweight Coated Paper
131
30.5 m
610 mm
C6029C (AEJN)
914 mm
C6030C
1067 mm
C6569C
67.5 m
1067 mm
Q1956A (EN)
HP Super Heavyweight Plus Matte Paper
210
30.5 m
610 mm
Q6626A (AEJN)
914 mm
Q6627A (AEJN)
1067 mm
Q6628A (AEJN)
HP Fluorescent Yellow Colored Paper
100
45.7 m
914 mm
Q1757A (E)
HP Yellow Colored Paper
92
45.7 m
914 mm
Q1760A (EN)
90 m
594 mm (A1)
Q6596A (E)
HP Technical Paper
HP Natural Tracing Paper
90
45.7 m
420 mm (A2)
Q1440A (J)
594 mm (A1)
Q1439A (J)
610 mm
C3869A
841 mm (A0)
Q1438A (J)
914 mm
C3868A
HP Translucent Bond Paper
67
45.7 m
610 mm
C3860A (AJN)
914 mm
C3859A (LN)
HP Vellum Paper
75
45.7 m
610 mm
C3862A (N)
914 mm
C3861A (LN)
HP Film (Technical and Graphic)
HP Clear Film
174
22.9 m
610 mm
C3876A (AEJN)
914 mm
C3875A
HP Matte Film
160
38.1 m
610 mm
51642A (AEJN)
914 mm
51642B
HP White Matte Polyester Film
167
15.2 m
914 mm
Q1736A (AEN)
HP Vivid White Glossy Polyester Film
230
20.1 m
610 mm
CG827A (EJN)
1067 mm
CG828A (EJN)
HP Photographic Paper
HP Universal Instant-dry Gloss Photo Paper
190
30.5 m
610 mm
Q6574A
914 mm
Q6575A
1067 mm
Q6576A
HP Universal Instant-dry Semi-gloss Photo Paper
190
30.5 m
610 mm
Q6579A
914 mm
Q6580A
1067 mm
Q6581A
The dye inks used by your printer will fade very quickly on instant-dry photo papers. If you plan to display the prints for more than two weeks, you should laminate them to achieve longer life.
HP Premium Plus Gloss Photo Paper
280
15.2 m
610 mm
Q5488A
HP Premium Plus Satin Photo Paper
280
15.2 m
457 mm
Q7920A
610 mm
Q5491A
HP Universal High-gloss Photo Paper
190
30.5 m
610 mm
Q1426A (AEJN)
914 mm
Q1427A (AEJN)
1067 mm
Q1428A (AEJN)
HP Universal Semi-gloss Photo Paper
190
30.5 m
610 mm
Q1420A (AEJN)
914 mm
Q1421A (AEJN)
1067 mm
Q1422A (AEJN)
HP RC Matte Photo Paper
200
30.5 m
914 mm
C7946A (AEN)
HP Backlit Material
HP Reverse Print Matte Backlit Film
160
22.9 m
914 mm
C7960A (AEJN)
HP Self-Adhesive Material and Laminate
HP Two-View Cling Film
240
22.9 m
914 mm
Q1914A (AEN)
1067 mm
Q1915A (AEN)
HP Self-adhesive Indoor Paper
170
22.9 m
610 mm
CG948A (EN)
914 mm
Q1733A (EJN)
HP Matte Adhesive-back Polypropylene
225
21.3 m
914 mm
Q1908A (AEN)
HP Colorfast Adhesive Vinyl
328
12.2 m
914 mm
C6775A
HP Adhesive-backed Polypropylene
128
50 m
914 mm
Q8044A (C)
1067 mm
Q8884A (C)
HP Everyday Adhesive Matte Polypropylene
180
22.9 m
610 mm
CG843A
914 mm
CG824A
1067 mm
CG825A
HP Self-adhesive Gloss Polypropylene
180
22.9 m
914 mm
Q8834A
1067 mm
Q8835A
Sheet paper
Paper type
g/m²
Length
Width
Part numbers
HP Coated Paper
90
610 mm
457 mm
Q1961A (AEJN)
914 mm
610 mm
Q1962A (AEN)
280
483 mm
330 mm
Q5486A
610 mm
457 mm
Q5487A
280
483 mm
330 mm
Q5489A
610 mm
457 mm
Q5490A
Order accessories
The following accessories can be ordered for your printer.
Name
HP Designjet PostScript Upgrade
CN500B
HP Designjet External Hard Disk¹
CN501A
HP Designjet T790 24-in Spindle
CQ783A
HP Designjet T790 & T1300 44-in Spindle
Q6709A
HP Designjet T790 24-in Stand
Q6663A
HP Jetdirect 635n IPv6/IPsec Print Server
J7961A
¹ Only compatible with T790PS and T1300 Printers
