HP EliteBook 8460p Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP EliteBook 8460p Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery pack (Primary) - 9-cell lithium-Ion (Li-Ion), 3.0 Ah, 100 Wh (CC09100)
631243-001 (Modified)
Yes
Battery pack (Primary) - 6-cell lithium-Ion (Li-Ion), 2.8 Ah, 62 Wh (CC06062-CL)
628668-001 (Modified)
Yes
Battery pack (Primary) - 6-cell lithium-Ion (Li-Ion), 2.55 Ah, 55 Wh (CC06055-CL)
628666-001 (Modified)
Yes
Battery pack (Long Life) - 6-cell lithium-Ion (Li-Ion), 2.8 Ah, 55 Wh (CC06055XL-CL)
628670-001 (Modified)
Yes
Battery pack (Primary) - 3-cell lithium-Ion (Li-Ion), 2.8 Ah, 31 Wh (CC03031-CL)
628664-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
The above mentioned video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
  2. On the bottom of the notebook, slide the battery release latch (identified with a battery icon) to the release position.
  3. Slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until it is properly seated and the battery release latch clicks.
  2. Slide the battery release latch to the locked position to secure the battery in the battery bay.
    Any red visible under the battery release latch indicates that the battery is not securely locked in the battery bay. This may allow the battery to slide out inadvertently and cause damage to the battery and anything it impacts.
Country: Flag Vietnam
