    Looking for Site Help?
Document ID: c02796032
Version: 1
Advisory: HP Easy Tools 2.1 - Unable to Change the Login Password if the Current Administrator Password Is Blank
Release date : 18-Apr-2011
Last updated : 18-Apr-2011
DESCRIPTION
After successfully logging into the system as Administrator, HP Easy Tools version 2.1 does not allow users to change to a new password if the current password is blank.
Symptoms:
Attempts to change the password are rejected if the existing administrator password is blank.
Figure 1.
sourceInformation
SCOPE
Information in this document applies to the listed systems configured as follows:
Systems:
  • HP gt7720 Thin Client
  • HP Compaq t5730w Thin Client
  • HP t5630w Thin Client
  • HP vc4820T Thin Client
  • HP t5740 Thin Client
  • HP t5570 Thin Client
  • HP t5740e Thin Client
Operating Systems:
  • Microsoft Windows Embedded Standard 2009 (WES 2009)
RESOLUTION
The administrator password cannot be changed via Easy Tools. Any changes to the password must be done via the "Control Panel" -> "Administrative Tools" -> "User Manager" applet.
Figure 2. The Local Users and Groups applet
  1. Select "Users" from the "Local Users and Groups (Local)" list.
  2. Select the Administrator entry for the list displayed in the right of the pane.
  3. Select the Action option from the menu bar followed by "Set Password...".
  4. At this point a warning dialogue should appear, click "Proceed" to enter the "Set Password for Administrator" dialogue.
  5. Enter the new password in the associated field and provide a confirmation. Click "OK".
  6. A confirmation popup should then appear that the new password has been set. Click "OK.
  7. Close the remaining Control Panel Applets.
Please send comments or questions about this Advisory to cdskt.author@hp.com, referencing this document number.
Hardware platforms affected : HP Compaq t5730w Thin Client, HP gt7720 Thin Client, HP t5570 Thin Client, HP t5630w Thin Client, HP t5740 Thin Client, HP t5740e Thin Client, HP vc4820T Thin Client
Support Communication Cross Reference ID : IA02796032
Country: Flag Vietnam
