    Fix HP Printer issue on macOS
HP xw4400 Workstation Product Specifications
Product features
Feature
Form factor
Convertible minitower
Processor and speed1
  • Intel Core 2 Extreme QX6700 processor/2.66 GHz, 4MB x 2, 1066 FSB, Dual-Core, Intel Virtualization Technology
  • Intel Core 2 Duo E6700 Processor/2.67 GHz, 4MB L2, 1066 MHz FSB, Dual-Core, Intel Virtualization Technology
  • Intel Core 2 Duo E6600 Processor/2.40 GHz, 4MB L2, 1066 MHz FSB, Dual-Core, Intel Virtualization Technology
  • Intel Core 2 Duo E6420 Processor/2.13 GHz, 4MB L2, 1066 MHz FSB, Dual-Core, Intel Virtualization Technology
  • Intel Core 2 Duo E6320 Processor/1.86 GHz, 4MB L2, 1066 MHz FSB, Dual-Core, Intel Virtualization Technology
  • Intel Core 2 Duo E6300 Processor/1.86 GHz, 2MB L2, 1066 MHz FSB, Dual-Core , Intel Virtualization Technology
  • Intel Core 2 Duo E4300 Processor/1.80 GHz, 2MB L2, 800 MHz FSB, Dual-Core
  • Intel Core 2 Duo E2160 Processor/1.80 GHz, 1MB L2, 800 MHz FSB, Dual-Core
Intel 975X
Memory
Up to 8GB of DDR2-SDRAM 667 MHz ECC unbuffered (8GB max) or non-ECC (2GB max) in 4 DIMM slots
Drive controllers
Integrated Serial-ATA (SATA) 3 Gb/s interface (4 SATA connectors), with RAID 0, 1, 0+1 capability; 1 EIDE interface (1 EIDE connector) for optical drives; opt. SAS controller with RAID 0, 1, 1E, and 10E capability
Hard drives
Up to 4 SATA drives (2 will require optional expander kits), 2TB max.; 80, 160GB (10K rpm) SATA 1.5 Gb/s; or 80GB (7200 rpm) SATA 3 Gb/s, 160, 250, 500GB SATA 3 Gb/s NCQ; or 146, 300GB (10K rpm) SAS 3 Gb/s or 73, 146, 300GB (15K rpm) SAS 3 Gb/s
Integrated SATA RAID
  • RAID 0, 1, 5, or 10 on a single array, up to 4 hard drives2
  • Support for 1 or 2 RAID arrays on 4-ports for RAID 0 or 1
  • RAID 1 spare and auto-rebuild
  • Matrix RAID support
  • AHCI support for NCQ drives
  • 3.0 Gb/s drive support
Optical drives
CD-ROM, DVD-ROM, CD-RW/DVD combo, DVD+/- RW Dual-Layer with LightScribe Direct Disc Labeling (Microsoft Windows XP 32-bit only, requires LightScribe media for labeling)
Drive bays
Three external 5.25-inch bays (opt. StorCase enclosure enables 3.5-inch SATA or SAS hard drive to be added to 5.25-inch bay), 2 internal 3.5-inch bays, 1 external 3.5-inch bay
Slots
Six full length slots: 1 PCI Express (PCIe) x16 graphics,1 PCIe x16 (x4 electrical) slot, 1 PCIe x1 slot, 3 PCI slots
Graphics
  • Professional 2D: NVIDIAQuadro NVS 285 (128MB, up to 2), NVIDIAQuadro NVS 440 (256MB) - NVS285 and NVS 440 can be mixed in a single system
  • Entry 3D: NVIDIA Quadro FX 560 (128MB), ATI FireGL V3300 (128MB)
  • Mid-range 3D: NVIDIA Quadro FX 1500 (256MB, up to 2 cards), ATI FireGLV7200 (256MB)
  • High-end 3D: NVIDIA Quadro FX 3500 (256MB), NVIDIA Quadro FX 4500 with opt. Quadro G-Sync card (512MB)
Audio
Integrated High Definition audio with Jack Retasking capability, opt. PCI Sound Blaster X-Fi XtremeMusic
Network
Integrated Broadcom 5755 NetXtreme Gigabit PCIe, opt. Broadcom 5751 NetXtreme Gigabit PCIe
Ports
  • Front: 2 USB 2.0, 1 headphone, 1 microphone, IEEE 1394A (optional)
  • Back: 5 USB 2.0, 1 USB 2.0 (internal), 1 standard serial port (opt. 2nd), 1 parallel, 2 PS/2, 1 RJ-45 to integrated Gigabit LAN, Audio In, Audio Out, microphone
Input devices
USB or PS/2 keyboard; choice of 2-button scroll mouse (optical or mechanical); USB 3-button mouse (optical); USB SpaceBall, USB SpacePilot
Monitors
HP L1955 19-inch flat panel, HP L2065 20.1-inch flat panel, HP L2465 24-inch flat panel
Basic 3 years next business day, parts, labor, and 8x5 phone support; terms and conditions may vary; certain restrictions apply
1: Intel processor numbers are not a measurement of higher performance. Processor numbers differentiate features within each processor family, not across different processor families. Click here to learn about intel processor numbers. Intel 64 Architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 Architecture. Processor will not operate (including 32-bit operation) without an Intel 64 Architecture-enabled BIOS.
2: Hardware RAID is not supported on Linux systems. The Linux kernel, with built-in software RAID, provides excellent functionality and performance. It is a good alternative to hardware-based RAID.Click here for RAID capabilities with Linux (in English).
Physical specifications
Feature
Chassis dimensions (H x W x D)
45.0 x 16.8 x 45.6 cm (17.7 x 6.6 x 17.9 in)
From 15.88 kg (35.0 lb), depending on configuration
Shipping weight
From 19.96 kg (44.0 lb), depending on configuration
Software overview
Feature
Operating systems
  • Microsoft Vista Business 32 or 64
  • Genuine Windows XP Professional SP2 (32-Bit)
  • Genuine Windows XP Professional x64 Edition (64-Bit)
  • Microsoft Windows Vista 32-bit downgrade to Microsoft Windows XP Professional
  • Microsoft Windows Vista 64-bit downgrade to Microsoft Windows XP Professional x64 Edition
  • Preloaded: Red Hat Enterprise Linux WS 4 (Update 4 or later) (32- or 64-bit version)
Power specifications
Feature
80 PLUS power supply option
460 W custom power supply - (Wide Ranging, Active PFC)
Operating voltage range
90 - 269 V ac
Rated voltage range
  • 100 - 240 V ac
  • 118 V ac
Rated line frequency
  • 50/60 Hz
  • 400 Hz
Operating line frequency range
  • 47 - 66 Hz
  • 393 - 407 Hz
Rated input current
  • 7.4 A @ 100 - 240 V ac
  • 7.4 A @ 118 V ac
Power supply fan
92 x 25 mm variable speed
Heat dissipation (configuration and software dependent)
Typical:
  • 283 kg-cal/hr (1121 btu/hr)
Maximum:
  • 609 kg-cal/hr (2415 btu/hr )
Power supply
475 W custom power supply - (Wide Ranging, Active PFC)
90 - 269 V ac
Rated voltage range
  • 100 - 240 V ac
  • 118 V ac
  • 50/60 Hz
  • 400 Hz
  • 47 - 66 Hz
  • 393 - 407 Hz
Rated input current
  • 10 A @ 100 - 127 V ac
  • 10 A @ 118 V ac
Power supply fan
Heat dissipation (Configuration and software dependent)
Typical:
  • 255 kg-cal/hr (1013 btu/hr)
Maximum:
  • 511 kg-cal/hr (2027 btu/hr)
Environmental specifications
Feature
Temperature
Operating:
  • 5° to 35°C (40° to 95°F)
Non-operating:
  • -40° to 60°C (-40° to 140°F)
Humidity
Operating:
  • 8% to 85%
Non-operating:
  • 8% to 90%
Maximum altitude (non-pressurized)
Operating:
  • 3,000 m (10,000 ft)
Non-operating:
  • 9,100 m (30,000 ft)
