    Looking for Site Help?
Document ID: c02752421
Version: 2
New HP Workstations are transitioning to new Advanced Format hard disk drive technology
Release date : 20-Apr-2011
Last updated : 31-Mar-2011
DETAILS OF CHANGE
Due to advancements in hard drive storage technologies, HP Workstations may be configured with a new industry hard drive technology known as Advanced Format which provides increased hard drive performance and reliability starting in the fourth quarter of 2011.
The new Advanced Format technology uses 4K byte sector boundaries for physical data storage on the hard drive, but will continue to communicate logically to the system in 512 byte sectors. These 512 byte logical sectors are known as 512 byte emulation or 512e, and are necessary to maintain compatibility with current and legacy operating systems.
Specific procedures are required to utilize the new 512e drives and for the drives to be accessed correctely. These procedures are required with legacy operating systems beginning with Microsoft Windows XP, as well as legacy versions of Linux based operating systems.
During the transition, systems with the Advanced Format hard drives and the existing 512 byte (512n) drives will be shipped until the supply of 512n systems are depleted. When receiving spare hard drives, the 512n drives will be shipped until the supply of 512n drives are also depleted.
sourceInformation
COMPONENT VERSION
Not applicable
REASON FOR CHANGE
HP is transitioning to Advanced Format technology in new HP Workstations to provide optimal hard drive performance and reliability.
This is to be considered an evolution of the technology intended to deliver increased performance. It is not specific to any one manufacturer, but rather is industry-wide in scope.
IMPACT OF CHANGE
  • Legacy operating systems, including Microsoft Windows XP and early versions of Linux, cannot accurately access the new drive technology without incorporating the necessary updates. Users will experience significant performance degradation unless the necessary software patches are deployed.
  • To align an Advanced Format hard drive for these older operating systems, HP recommends that you assess your usage environment and if necessary, follow the procedures outlined in the Preparing Advanced Format hard drives for Microsoft Windows installations on HP Business Notebook PCs and Desktop PCs.
  • Using an Advanced Format hard drive in the following operating systems should not require any extra actions, software updates or drivers:
    • Microsoft Windows 7
    • Microsoft Windows Vista SP1 or higher
    • Microsoft Windows PE 2.1 or higher
    • SuSE Linux SLE11-SP1 or higher
    • RedFlag Linux v2.6.31 or higher
Although these operating systems are compatible with Advanced Format, alignment issues may occur when using older third-party deployment tools. Contact the deployment tool vendor for more information on the deployment tool's ability to work with Advanced Format hard drives. If you are using an HP factory image on your system, no action is required.
The Effective Date is normally the earliest date this change may be implemented in the factory.
The Effective Date is subject to change.
Customers who use "Golden" images or “locked” configurations should test with the changes listed in this PCN.
Components affected:
HP hard disk drives shipped on all HP Workstation platforms or provided as part of aftermarket option (AMO) kits manufactured during or after the fourth quarter of 2011.
REVISION HISTORY : Version 2
DATE OF CHANGE
Effective date : 01-Sep-2011
Hardware platforms affected : Workstations
Country: Flag Vietnam
