    Fix Windows 10 Update Issues
HP LaserJet M3027 and M3035 Multifunction Printer Series - Replace the Staple Cartridge
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Staple cartridge replacement
  1. Open the stapler door.
    Opening the stapler door disables the stapler.
  2. Remove the old staple cartridge from the device.
  3. Insert a new staple cartridge into the opening inside the staple door.
  4. Close the stapler door.
Parts return
