HP LaserJet P3005 Printer Series - Replace the Memory
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Memory replacement
Static electricity can damage DIMMs. When handling DIMMs, either wear an antistatic wrist strap or frequently touch the surface of the DIMM antistatic package, then touch bare metal on the device.
The HP LaserJet P3005 devices come with one DIMM slot. If desired, you can replace a DIMM installed in the slot with a higher memory DIMM.
If you have not already done so, print a configuration page to find out how much memory is installed in the device before adding more memory.
  1. After the configuration page has printed, turn the device off and disconnect the power cord.
  2. Disconnect all interface cables.
  3. Remove the right side panel by sliding it towards the rear of the device until the side slides from the device.
  4. Open the access door by pulling on the metal tab.
  5. Remove the DIMM from the antistatic package.
    To reduce the possibility of damage caused by static electricity, always wear an electrostatic discharge (ESD) wrist strap or touch the surface of the antistatic package before handling DIMMs.
  6. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot. (Check that the locks on each side of the DIMM slot are open.)
  7. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
    To remove a DIMM, first release the locks.
  8. Close the access door, and press firmly until it snaps into place.
  9. To replace the right side panel, line up the alignment arrows and slide the panel toward the front of the device until it latches into place.
  10. Reconnect the interface cable(s) and the power cord.
  11. Turn the device on.
Parts return
