HP 100B All-in-One PC Specifications
Product description
The HP 100B All-in-One Business PC combines everyday business computing with exceptional performance value. The streamlined design makes this PC productivity central with powerful AMD technology, we can multi-task right out of the box.
Product features
Feature
AMD A45 FCH (Fusion Controller Hub)
Processor and Graphics
AMD Dual-Core Processor E-350 with AMD Radeon HD 6310 Discrete-Class Graphics
20-inch diagonal
Resolution
1600 x 900 resolution
Contrast ratio
700:1
Image brightness
250 nits typical
Typical reponse time
5 ms
Vertical viewing angle
70°
Horizontal viewing angle
75°
Memory
Up to 8GB PC3-10600 SODIMM Memory (2 SODIMM slots with up to a 4GB SODIMM in each slot)
NIC
10/100/1000Base-T network interface
HP Wireless LAN 802.11b/g/n 1 x 1 Mini Card
Keyboard
HP USB Standard Value keyboard
Pointing device
HP USB optical mouse
Storage
  • 250GB 7200 rpm 3.0 GB/s Serial ATA hard drive
  • 500GB 7200 rpm 3.0 GB/s Serial ATA hard drive
  • 750GB 7200 rpm 3.0 GB/s Serial ATA hard drive
Optical drive1
  • Slim Tray SuperMulti DVD Burner with LightScribe Technology
  • Read: 8x max DVD-ROM, 24x max CD-ROM
  • Write: 8x max DVD±R, 6x max DVD±R DL, 8x max DVD+RW, 6x max DVD-RW, 5x max DVD-RAM, 24x max CD-R, 24x max CD-RW
Interfaces
USB 2.0
6 USB 2.0 ports (2 left side, 4 back) (6 ports available)
Microphone jack
1 (Left Side)
Audio headphone jack
1 (Left Side)
RJ-45/Ethernet
1 (Back)
Line-out
1 (Back)
1 PCI-E x1 mini socket slot (occupied)
Audio/Visual
Integrated high-definition audio with 2.0 sound capabilities and high-performance 2.0 speakers
1: Performance above 3.0 GB/s may not be available due to system resource requirements.
Input devices
HP USB standard keyboard
Specification
Physical characteristics
Keys
104, 105, 106, 107, 109 layout (depending upon country)
Dimensions (H x W x L)
15.3 x 2.74 x 46.1 cm (6.02 x 1.07 x 18.14 in)
0.6 kg (1.3 lbs) minimum
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
50 mA maximum (with three LEDs On)
ESD
CE level 4, 12.5 kV air discharge
EMI - RFI
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001
Functionally compliant
Mechanical
Languages
40 available
Keycaps
Slim design
Switch actuation
60 g nominal peak force with tactile feedback
Switch life
10 million keystrokes (using Hasco modified tester)
Switch type
Contamination-resistant switch membrane
Key-leveling mechanisms
N/A
Cable length
150 cm
Mechanically compliant
Acoustics
50 dBA maximum sound pressure level
Environmental
Operating temperature
10° to 50°C (50° to 122°F)
Non-operating temperature
-30° to 60°C (-22° to 140°F)
Operating humidity
10% to 90% (non-condensing at ambient)
Non-operating humidity
20% to 80% (non-condensing at ambient)
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
2 g peak acceleration
Non-operating vibration
4 g peak acceleration
Drop (out of box)
76 cm (30 in) on carpet, 5-drop sequence
Drop (in box)
76 cm (30 in) on rigid surface, 10-drop sequence
Approvals
  • ULcUL
  • FCC
  • CE
  • TUV/Bauart
  • VCCI
  • BSMI
  • C-Tick
  • KCC
Ergonomic compliance
N/A
HP USB 2-Button optical scroll mouse
Specification
Scroll wheel
24
Maximum rotation speed
48 rats/sec
Switch type
Wheel
Switch life
  • Button: 1,000,000
  • Wheel: 200,000 times
Environmental
0° to 40°C (32° to 104°F)
-20° to 60°C (-4° to 140°F)
Operating humidity
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
Electrical
Operating voltage
4.35 to 5.25 V dc
Power consumption
<100 mA
MTBF
>150,000 hrs
ESD
  • IEC-61000-4-2 criteria B
  • Contact discharge: +/- 4 kV
  • Air discharge: +/- 8 kV
EMI-RFI
FCC Class B
PC98
PC 99 Compliant
Mechanical
Resolution
500±10% dpi
Tracking speed
25 cm/sec
Acceleration
0.05 cm
Switch actuation
60 gf (0.6 N)
Switch life
  • Button: 1,000,000
Cable Length
180 cm
PC98-99
PC99 compliant
Regulatory approvals
  • ULcUL
  • FCC
  • CE
  • TUV/GS
  • VCCI
  • BSMI
  • C-Tick
  • MIC
Hard drives
Specification
Serial ATA Hard Drives (7200 rpm) 250GB
Capacity
250,059,350,016 bytes
Height
2.54 cm (1 in)
Width
  • Media diameter: 8.9 cm (3.5 in)
  • Physical size: 10.2 cm (4 in)
Interface
Serial ATA (3.0 Gb/s)
Synchronous transfer rate (Maximum)
Up to 3 Gb/s
Buffer
8MB
Seek time (typical reads, includes controller overhead, including settling)
  • Single track: 2.0 ms
  • Average: 11 ms
  • Full-stroke: 21 ms
Rotational speed
7,200 rpm
Logical blocks
488,397,168
5° to 55°C (41° to 131°F)
Serial ATA Hard Drives (7200 rpm) 500GB
Capacity
500,107,862,016 bytes
Height
2.54 cm (1 in)
Width
Interface
Up to 3 Gb/s
Buffer
8MB
  • Average: 11 ms
Rotational speed
7,200 rpm
Logical blocks
976,773,168
Serial ATA Hard Drives (7200 rpm) 750GB
Capacity
720,176,893,706 bytes
Height
2.54 cm (1 in)
Width
Interface
Synchronous transfer rate (maximum)
Up to 3 Gb/s
Buffer
8MB
  • Average: 11 ms
Rotational speed
7,200 rpm
Logical blocks
976,773,168
Power
Specification
Standalone power requirements
Electrical ratings
100 to 240 V
Average operating power
43 W
Max operating power
90 W
Physical specifications
Specification
36.61 x 9.28 x 50.18 cm (14.41 x 3.65 x 19.75 in)
5.0 kg (11.02 lbs)
Software/OS
Feature
  • Cyberlink DVD Suite Deluxe
  • Microsoft Office Home and Business 20101
  • Microsoft Office Professional 20101
  • Norton Internet Security 20112
  • HP Power Assistant
  • Microsoft Windows Virtual PC – XP Mode
  • HP Recovery Manager
  • Microsoft Internet Explorer
Operating System
Preinstalled:
  • Genuine Windows 7 Professional 32-bit
  • Genuine Windows 7 Starter 32-bit
  • Genuine Windows 7 Home Basic 32-bit
  • FreeDos
  • Red Flag Linux
1: Purchase of a Product Key required to activate a full Office 2010 suite.
2: Preinstalled security software helps protect you from viruses, spyware, and other online threats, right out of the box (60 days of complimentary live updates).
Environmental specifications
Specification
Temperature
Operating
10 to 40°C (50° to 104°F)
Non-operating
-30° to 60°C (-20° to 140°F)
Relative humidity
Operating
20% to 80%
Operating altitude (unpressurized)
2,28600 cm (0 to 7,500 ft)
Non-operating altitude
4,57200 cm (0 to 15,000 ft)
Industry standard certification
ENERGY STAR 5.0 qualified
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
